#16
Re: Re: Acctual 350 Gas Mileage
Wow, What kind of trans do you have in this? Mine defiantley does not shift like that. 1-2 about 20, 2-3 about 40, 3-4 about 55.
Matthew Brough ![]() 1997 Geo Prizm -- 301,000 miles 2000 Honda Accord -- 225,000 miles 2004 GMC Yukon XL -- 223,000 miles 1987 Jeep Comanche -- 116,000 miles |
#17
Re: Re: Re: Acctual 350 Gas Mileage
Anyways, I think its a 700R4, 4-spd auto with overdrive.
**1966 Chevy II** ![]() 355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4 Last Race (10-6-07) So its been awhile... Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph Fastest Pass of '07 (10-6-07) 60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph 25 and in BIG TIME Debt Crew member #2 Deuce's Wild Racing: Take a Ride on the WILD SIDE
#18
That's what i have, 700r4. If your truck is newer than a 95, i think you would have a 4L60E
#19
Its a 92. When I left work thsi morning, i got on it after it shifted out of 1st, but not alot and it was still in 3rd at 55 mph. I'm pretty sure when you floor board it from a dead stop, it stays in 2nd (might be third, but I was thinking its 2nd, since 2nd is passing gear) untill 65 mph. Either way, whatever gear that is, thats my truck's power gear, as long as its in that gear, it will fly.
#20
I try not to get on my throttle to much, unless I'm running to a fire scene or something. (I am a volunteer Fireman) I have burnt up two transmissions in this truck from driving it like it was an indy car!!!
I love my truck though. I bought it from the city I work for. It use to be my work truck so I know exactly what has been replaced, what's wrong with it, and what it has been through. I bought it after I smoked the last transmission. The city just parked it and I offered them a hundred dollars for it and the gave me the title. Put a new seat and transmission in it and it runs like a brand new one!
#21
I don't go around wide open all the time either, lol. My papaw bought my truck brand new and then my dad bought it from him after it was 2 years old. So I know everything thats ever been done to or happened to this truck as well. In 118,000 miles, the only major problem it had was the torque converter, and that happened when it was still under warranty.
Sounds like you praticaly stole that truck! Shoot, if it didnt have a motor or transmission in it it woudl be worht way more then $100! lol
#22
My 99 2wd Yukon Vortec 350 with 4l60e was getting 14 hwy (75-80mph)around 60,000 miles.
I put in a b&m shift kit, K&N cold air intake, and dual 2.5" cat back with a dual in dual out 50 series flowmaster. At the same time I noticed a few pulleys slightly out of round and it turned out to be the tensioner and the crank pulley. With all that plus a new intake gasket, waterpump, and now running mobil1 in the oilpan I brought it back up to 20 mpg with 94,000 on the odometer. Not bad for a 6,000lb suv with 3.73 gears I think. If you aren't sure of your gears I have the rpo list on my site HERECLIK FOR RPOs |
#23
I stand corrected thank you. now i know!
#25
i have a 97 with a 350 and mine was rated at 13/15 but when i figured it myself(divided miles on a tank to tank size) i got just over 10mpg. but with true dual flowmaster exhaust i almost have to stomp on it all the time and hear the thunder so that mite contribute to the lesser mpg.
#26
a K&N air filter will help your gas milage, as long as you're not heavy on teh throttle. Also, get this stuff called seafoam. Its in a can, and you can buy it at NAPA or someplace similar. Suck about 1/3 of the can through a vaccum line going up to the intake manifold or whatever, and put the rest in with your gas. There will be more detailed directions on the can. everyone on the message board on corsicas.com that has used it loves it, so you might as well give it a try. It could increase gas milage a bit, and also help with performance, as it will clean up the inside of the intake manifold and valves and stuff
#27
I get like 15 on my swb 2wd stepside. That's even with a cracked air dam.
#28
If anyone is wondering what gear their rear end is, there is a very easy way. Pop open your glovebox and the sticker with all the codes, just match the code to the rear end below. Of course this is only if your rear end hasn't been modified or replaced with another rear end in the past.
GK9 Rear Axle: 4.63 Ratio GTY Axle Wide Track GT4 Rear Axle: 3.73 Ratio GT5 Rear Axle: 4.10 Ratio GU4 Rear Axle: 3.08 Ratio GU6 Rear Axle: 3.42 Ratio G80 Rear Axle: Positraction HC4 Rear Axle: 4.56 Ratio HC7 Rear Axle: 5.13 Ratio
-Page [email protected] 1998 Chevy C1500 1998 Volkswagen Beetle 1993 Jeep Wrangler |
#29
#30
I recently purchased a 96 Z71 and it only gets about 10mpg in the city. It has the 3.73 rear end and the previous owner removed the converters.
I installed the 40series flowmasters ans it is loud really loud (nice). I was told that the removal of the converters is not only illegal but would also hurt the gas mileage and reduce my low end torque. I have a 00 5.3ltr that will leave it in the dust. Whats my problem???? |
