Old 04-27-2004, 02:49 PM
Lotus49 Lotus49 is offline
Send a message via Yahoo to Lotus49
*sighs* waiting for the jbweld to dry
Old 04-27-2004, 03:26 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
i doubt you'll have much luck with jb weld. you'd have to grind all the paint off the area and get a real clean surface. do you have access to a mig welder? i think your pan is steel, and if you drain all the oil out and take your time doing a series of spot welds you shouldn't have a problem with heat or catchin anything on fire
Old 04-27-2004, 03:31 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: A hole in the Oil pan
well if its not a huge hole the jbweld should hold up for a while, but i would still plan on replacing the oil pan,do you have access to like a base hobby shop??
Old 04-27-2004, 03:40 PM
well i sanded and got rid of all the paint and shit around the hole.. the hole is about the side od a pencil eraser.. maybe even smaller... i drained all the oil out..(well what was left) and took a torch to the area i was jbelding, to get rid of any grease and oil.. then i sanded it again..
To take out the oil pan.. which is only 60 bucks at napa.. the engitre suib frame has to come out.. either that or i have to lift the engine out. i do work in a garage.. but my boss would never let me tie up a bay to do that job, even so... i live 3 miles away from work and id have no way of getting it there... if this jbweld dosent work im just going to mig weld it..(or is it tig weld?)
Old 04-27-2004, 04:48 PM
damn if its that small the jbweld will last a while
Old 04-27-2004, 05:10 PM
hey if it will last me long enough to sell it then im good
Old 04-27-2004, 05:16 PM
lol, im sure it will, just paint over it after it dries
Old 04-27-2004, 07:15 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
well shit if that jbweld stuff is good enough to fill a crack in a head than im sure it will hold back oil through a pencil hole...
Old 04-27-2004, 07:23 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
that's what your dumbass gets for letting someone borrow your car.
