Originally Posted by corbinwaterski
Did you just recently purchase/install the wiring harness for the trailer lights? If so I know with the Tacomas people have had problems with the no-name(non-Toyota) harness. It was causing symptoms similar to the ones you are describing. Good luck!
I think you've just blown a fuse. My 99 Tacoma used to do that--if the brake light fuse blew the trans wouldn't shift out of park, and you had to pry up the quadrant cover and press the little button to get it out of park. The owner's manual for mine described the procedure
