Old 05-29-2004, 07:07 PM
AKWE-gt AKWE-gt is offline
Re: I need help bad, electrical issues making my hair gray!
i was wondering if you ever checked the connection where the wires plug into the firewall. i once had a buick and it had the same kind of problems your car has, it turned out to be that plug. some of the connections were corroded or just dirty.
Old 05-31-2004, 04:01 PM
Murphyg Murphyg is offline
Im thinkin if it wont fire might be something to do with fuel flow.
Could change the fuel filter if it hasent been done in a while. 15000 miles (20000 Km) or every year is good.
Or may be something with your (sic) fuel pump.
Any idea if this occurs with your tank near low? Or is it at any time?
Old 05-31-2004, 05:08 PM
Wayfarer696 Wayfarer696 is offline
I havent check'd any connections on the firewall, i thought the wires just went through some bushing for weather proofing and protection from the metal. i'll check that out, i havent had it running long enough to run it low in fuel since this problem started, i did check pump fuses and swaped the fuel pump relay with one out of my buddy's car "same exact relay", and that didnt do anthing, and i can hear my fuel pump turning on with the ignition and stopping a few seconds later, "like its building up pressure and waiting for the engine to start." I also seem to get plenty of fuel @ the fuel rail pressure check-point. but i dont have a gauge to check actuall amount of pressure. I also checked all injectors, and found one reading only 6.5 ohms, so i replaced it. and that didnt change anything.any tips on what wires could be shorting out to or from the fuel pump? or what kind of voltage or resistance i should have? Thanks again for the great tips, and i'll get out and see what i can find.
peace,
wayfarer696
Old 09-01-2004, 12:45 PM
sky2k4's Avatar
sky2k4 sky2k4 is offline
Send a message via MSN to sky2k4 Send a message via Yahoo to sky2k4
Angry having simular probles
car was running sweet then a half hour later i got to srart it and it sounds like crap,missing and my coollant light came on,so i try to drive it to a firestone,they hook it up to diagnostics,and get code 34 and 42 wich i have no meaning too,they say that the computer is bad and so i go and get a notther one for 20.00 put it in, thinking this should help,well it diddnt and now im still getting those codes and only getting 3.3 amps and not 5.00 readings,
does anyone know were or what kinda problems this is and any ifo on this subject,man this sucks!
Old 09-03-2004, 08:55 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I believe you may have a crank sensor problem. In all of your previous posts, I haven't seen you mention it. It's a simple job and a common no start issue on 2.8 and 3.1's
