#16
Re: cracked camry radiator repair
Just a note..... JB Weld does have a "Kwik" set....
Bonds in 4 minutes, I have used it & sets up quickly... I would still let your repair set-up over night... I would also clean with rubbing alchol with a stiff brush so it gets down into the crack... Bob |
#17
NyloBond fix, Re: cracked camry radiator repair
You can fix your cracked radiator's nylon tank top inexpensively. I did this repair myself in 2006 and it's still running well in 2011. (On my 1992 Camry's radiator; 3.0 liter engine). Get a NyloBond repair kit. About $7 (seven) per kit I paid in 2006. I bought two at once in a mail order from the company. They don't often sell to individuals, so be nice. Or, better yet, call your local independent auto parts shops, and ask them to stock NyloBond. I got it from Johnson Manufacturing NyloBond is apparently often used to repair the large tanks on Mac trucks and 18-wheelers. Instructions say to apply the nylon paste (and mesh) on both sides of the crack for the best repair. But, it's hard to reach inside the radiator tank. So, I cleaned it extremely well, and only applied paste to the outside, covering the crack. Then, you point a heat lamp at it and let it sit. Best not to do this in the cold Winter; but it might work if you had to. Kit came with thorough instructions; use them if you want it to work. My Camry's radiator has not leaked one drop since my repair. Regardless, I check it regularly, along with my oil level. Newer cars' radiators have an aluminum body and a nylon tank top. Yes, it's nylon, not plastic. Old radiators were all copper. My other 1995 Camry's radiator tank top also cracked in the same place. A hairline crack about 2 inches long; just a half inch below the very top of the tank. You notice the green antifreeze below and around the crack. Fix it soon. Until you repair it, check your engine coolant (antifreeze) level every time before you drive. Until you seal that crack, sometimes, coolant leaks out a lot; sometimes, it doesn't. The crack may expand or contract depending on outdoor temperature fluctuations. But after I did my NyloBond repair, it's been clean and not leaked a drop through New England winters and summers. If you can spend $250, just get a mechanic to replace your entire radiator. But, times are tough for some, and if you're low-income and handy, then you can do it yourself like I did.
#18
Re: NyloBond fix, Re: cracked camry radiator repair
I patched up a hairline crack on the top of the radiator of my 1989 Camry using J.B. Weld epoxy. I prepaired the area to be patched by using my dremel and an grinding attachment on it to roughen up the area where the epoxy was to be applied. I then used rubbing alcohol and a toothbrush to thoroughly clean the patch area. Applied the J.B. Weld and let it dry overnight. It has been around 2-3 months since and so far it has held up great. Below are a few pics. of the patch job.
![]() ![]() I used the standard J.B.Weld for this job. The 15 minute J.B. Weld setup would have been a better choice. Not as many runs : ) JOET/CAMRY |
