Old 04-17-2004, 08:22 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Sensor Problems
didnt i already say that?
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 04-17-2004, 08:40 PM
phantomz28's Avatar
phantomz28 phantomz28 is offline
Send a message via AIM to phantomz28
Re: Sensor Problems
ahh yes you did i didnt catch it
Old 04-17-2004, 08:43 PM
89IROC&RS's Avatar
Re: Sensor Problems
eh, i was just elbowin ya, still good advice, regardless of how many times we pound it into his head
Old 04-17-2004, 09:58 PM
sykotic1 sykotic1 is offline
Re: Sensor Problems
the way they were trying to explain it to me the sensor isnt sending the right information because of the loss of cats. thats why high flow cats were suggested, i dunno? oh i should mention he told me to take it to an exhaust shop for that and they dont get into that kind of work thats why i thought he was just tryin to help.
Old 04-17-2004, 11:08 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
i really cant see how a cat would effect the O2 unless it create's a little backpressure so more exhaust stays in the pipes, and the O2 gets a little better reading, in which case it would seem kinda contradictory to put on high flow cats. i think the best bet is that the O2 is just plain junk. i would not recommend O2 simulators, ur giving the ecm one constant reading which isn't always going to be right, and on some days you'll see an improvement while other days it's gonna hurt gas milage and performance, and you'll wind up with fouled plugs..again
Old 04-18-2004, 12:23 AM
phantomz28's Avatar
Re: Sensor Problems
well you need to realize that the simulators are calibrated to make the engine run most efficent and get the most power. itis no more different thatn having the best high flow cats . it just affects the emissions mostely. it does not harm the computer. the one thing that does hower is the AIT simulator. this will be what will damage your engine
Old 04-18-2004, 01:42 AM
Re: Sensor Problems
my heads starting to spin hehe. its been running better since having everything tuned but i still need some new plug wires which i should have soon. thanks for the help.
Old 04-18-2004, 10:18 AM
4onFloor's Avatar
Re: Re: Sensor Problems
in a sense, yes they are calibrated to make the engine run most efficient, assuming that all running conditons are perfect. there telling the ecm that the mixture is right at 14.7:1 or what ever there programmed to tell and basing it's pulse width on that. but, while you can control what the ecm thinks the mixture is, you cannot control the numerous things that effect what the mixture should be: outside air temp, barometric pressure, air density, engine temp etc. your essentially running the ecm in open loop which is what it does for approximately 2 minutes of a cold start up. it bypasses the O2 and runs the engine off factory programmed settings, then it goes into closed loop once the engine is warmed up. i'll give an example, lets say you have O2 simulators and you start your car up on a 65 degree day and the sun is shining and your goin down the highway, the ecm goes into lean cruise mode wich is essentially open loop but it lean's out the mixture a little then bounces into closed loop every now and then to double check itself. the car is running good cause all conditions are near perfect, then it starts to rain and the outside temp drops 10 or 15 degrees, now the air is cold and dense. now the mixture doesn't like to attomise and runs like shit, but your O2 simulators is saying that everything is great. see what i'm gettin at? your paying for an O2 simulator, hurting performace and gas milage, and eventually damaging engine components cause you dont wanna buy a $20 O2 sensor. sorry to string this out but a little hard to explain
Old 04-18-2004, 12:27 PM
phantomz28's Avatar
Re: Sensor Problems
the o2 simulators are after the cats. this isnt changing what the air intake is. o2 simulators are safe. this thread was a popular one on my other fourm. the only one that matters to engine performance is the intake temp senser. the o2 simulators just read the gases after the cat. and if the cats are bad they read that the gases are too high. o2 simulators act like cats. they just let the exhaust gases be within standards. if the outside air changed the IAT senser would change the mixture and timing. and when it reads what the o2 senser (or o2 simulators) are readhing is reading that the cats are doing their job and keep the engine running efficient. i have never heard anywhere of o2 simulators harming an engine. the only reason their not street legal is for emission standards. and btw it goes into closed loop when the engine is on for more than 2 min, your crusing speed is about 70 mph, temp above 160 (i think thats the temp) i forget teh other variable. but the emission system is rarely used. alot of people think removing it will give more power but it dosent. when it goes into closed loop it recycles some of the exhaust gases. ive never heard of it "checking" itself. and the o2 sims dont hurt gas mileage they HELP it, it sode not dammage the engine and its just teling the comupter that the cats are running to their efficiency. i have has the simularots insalled for 4 months and my car idols a hella lot smoother, i got an extra mile to the gallon, and the performance is lot smoother and "thier"
Old 04-18-2004, 12:29 PM
89IROC&RS's Avatar
Re: Sensor Problems
well the way i see it, is you have O2 sensors upstream AND downstream of the cats. so for the sensors north of the cat, no problem, for the ones south of the cat, its a big deal, because the cat scrubs out excess HC that isnt burned in the engine, when the cat isnt there, that excess fuel coats and burns onto the O2 sensor, so its actually the sensor that fouls out, but this should also be making your engine run lean, not fat, so you could be burning your plugs with a too hot chamber, but then youd also be getting high NOx, so i dont know exactly what to tell ya. have you had the emissions ran sense this problem occured????? you can ask to have a tune up emissions test, and they cant fail you for that i think.
Old 04-18-2004, 02:03 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
I would not simulate the 02 sensors on a TPI car. unless you want a constant set A/F raito that will kill your gas milage.( and with gas prices a 2.00 a gallon...) That sensor regulates fuel. The 02 simulators are to simulate the 02 sensors that controll the emmissions on the LS1 cars, which are the back two sensors. ( which as you all know has 4 o2 sensors) and to remove the cats and not trip the SES light on
You need to find out what the signal output of the o2 sensors, I think it should be between 760 and 800 milivolts at WOT. If they arenot within that spec, get an adjustible fuel pressure regulator and adjust the fuel pressure to conpensate.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 04-18-2004, 05:38 PM
4onFloor's Avatar
sorry i thought you were talking about the upstream O2. and yes your right, the ecm does go into closed loop after 2min, which is what i said. i said it runs in open loop for the first 2 min
Old 04-18-2004, 07:54 PM
KaotiKCamaro5's Avatar
KaotiKCamaro5 KaotiKCamaro5 is offline
Send a message via AIM to KaotiKCamaro5
Re: Sensor Problems
Just so im up to speed..? Sry guys.. im new, im learnin.. But i guess ya gotta start somewhere.
"doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87
LE123456712: i promise i will stop filling your email with my boobs
Kieft125: lol.. good, its starting to get rediculous..
Old 04-18-2004, 08:29 PM
89IROC&RS's Avatar
Re: Sensor Problems
thats the pre cat O2 sensor, the other one should be in the exhaust pipe after the cat.
Old 04-18-2004, 08:38 PM
Re: Sensor Problems
? well.. only other one i have seen is this one, on the other side. about a year ago i had the catalytic converter cut off, and had an exhaust put on..
