Old 04-03-2004, 02:12 PM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
Re: Is this car worth it? 99 SS?
Come on, you can't base real life on a game!
Old 04-04-2004, 01:29 AM
fishnredneck fishnredneck is offline
Send a message via AIM to fishnredneck
Hey992 RS where is the pic of that camaro taken at? Which Track?
Old 04-09-2004, 05:28 PM
c a m a r o c a m a r o is offline
Banned
410s decrease top speed right? is there a way to increase top speed by putting higher rear gears in on a stock camaro or are the gears on the camaro the minimum? gran turismo has camaros? i thought it was rice cars?
Old 04-09-2004, 10:11 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
rearend gearing does dramatic changes to your top speed. i used to have a 2.73 on my camaro (it's pictured w/ that rearend) now i have a 3.42 posi and it will accelerate off the line dramatically faster. the drawback tho, i took down my top speed from about 140, to about 100. my top speed is incredibly low right now. like i said, dramatic changes, if you want to increase top end then you give the rear a shallower gear, if you want better acceleration, deeper rear end helps alot.
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 04-09-2004, 10:21 PM
Banned
then how do drag cars go over 200mph with 410s? high rpms? the way i see it w/ 410s if its in a 1:1 gear the engine would have to spin 4 times faster than the wheels. wouldnt the car be faster with higher gears if it has enough torque to compensate for the loss in acceleration?
Old 04-10-2004, 02:12 AM
I guess if that same car had 2.73s it would have over 25% less acceleration while the top speed would increase by the same factor.
