Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-15-2004, 05:31 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: 94 Del Sol w/B16a JDM swap California ?s
The USDM Del Sol VTEC used the P30 ECU from '94 - '95. This is an OBD1 ECU and should be compatible with your motor.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 03-16-2004, 10:32 AM
systemt systemt is offline
Thanks again for the info guys. I spoke with the CHP... They said the vechicle MUST be street legal if I drive it in for the VIN verification. They also said if I trailer it in then it doesn't matter - sounds like the way to go! I will then deal with the state ref and smog. Looks like the AEM cold air intake has a CARB# and so does the DC header. What about Trust exhaust, been unable to find any CARB info??
Anyone know how to identify the ECU that is currently on the car? I'm assuming it is the gold box that is mounted on the passanger floor - It does have a sticker with numbers on it...
So... the P30 ECU from 94-95 will work with a B16A from 2000? Just making sure. Anyone have a spare ECU?
Old 03-16-2004, 10:41 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Actually, I think you need the ECU from the motor, so in your case that would be a P2T, in which case you would have to get an OBD IIb to OBD I harness. Now I am not totally sure if you have to run the motors ECU, or if you have to have the comparible ECU for the generation of the car.
