#16
Re: VR4 or Supra TT???
they say that every 100 pounds is 1/10th off of the timeslip
#17
check this out
Specifications Year 1993 Origin Not Available Make Toyota Base Price $38 000 usd Model Supra Turbo Production Not Available Engine & Transmission Body / Chassis Position Not Available Drive Wheels Front Engine / RWD Configuration Twin Turbo Inline-6 Curb Weight 1565 kg / 3450 lbs Valvetrain DOHC 4 Valves / Cyl Length 4514 mm / 177.7 in Displacement 2997 cc / 182.9 cu in Width 1811 mm / 71.3 in Power 238.6 kw / 320.0 bhp @ 5800 rpm Height 1275 mm / 50.2 in Torque 427.1 nm / 315.0 ft lbs @ 4000 rpm Wheelbase 2550 mm / 100.4 in Bore 86.1 mm / 3.39 in Front Track 1521 mm / 59.9 in Stroke 86.1 mm / 3.39 in Rear Track 1527 mm / 60.1 in Redline 6800 rpm Steering Rack & Pinion w/Power Assist HP / Liter 106.77 bhp per litre Body / Frame Unit Steel HP / Curb Weight Front Brakes Vented Discs w/Vacuum Assist & ABS Gear Type 6-Speed Manual Front Brake Size 323 mm / 12.7 in 1st Gear Ratio 3.83:1 Rear Brakes Vented Discs w/Vacuum Assist & ABS 2nd Gear Ratio 2.36:1 Rear Brake Size 325 mm / 12.8 in 3rd Gear Ratio 1.69:1 Front Wheels F 43.2 x 20.3 cm / 17.0 x 8.0 in 4th Gear Ratio 1.31:1 Rear Wheels R 43.2 x 24.1 cm / 17.0 x 9.5 in 5th Gear Ratio 1.00:1 Front Tires 235/45ZR-17 6th Gear Ratio 0.79:1 Rear Tires 255/50ZR-17 7th Gear Ratio Not Available Front Suspension Not Available Final Drive Ratio 3.27:1 Rear Suspension Not Available Performance Top Speed 249.4 kph / 155.0 mph 0 - 60 mph 5.0 seconds 0 - ¼ mile 13.5 seconds 0 - 100 mph 11.8 seconds Lateral Acceleration 0.98g EPA City/Hwy 18 / 23 mpg More like 300lbs 3kgt vr4 Engine 3L 6cyl 24V DOHC HP 300 @ 6000rpm Torque 307 @ 2500rpm Compression 8:1 MPG 18/24 Wheelbase 97.2" Length 180.5" Curb Weight 3,793 lbs Transmission 5-spd Getrag Wheels 17"x8.5" Alum. Tires 245/45ZR17 Lateral Acceleration .948g
lets just say this both cars are extremely sweet cars and most people would do almost anything to have either one they are both very nice and fast cars
