Old 03-09-2004, 01:14 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Re: Re: how to remove limiter?
Ohh yah, on the gutted cat note. First of all, the gutted cat came like that when I bought the car and haven't had the time to replace it which I DO plan on doing with a Y8 catalytic converter. Second of all, the honeycomb inside the cat is restrictive in a different way and is not related to exhaust piping diameter.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 03-09-2004, 01:20 PM
91civicDXdude's Avatar
you're all about the "low backpressure" exhaust flow, and smooth flowing, but that huge gaping gutted cat is the same thing as a 3" exhaust pipe.
and no sir, i am not a know it all, i just know more than you.
ricer
Old 03-10-2004, 10:53 PM
QuikShifter's Avatar
QuikShifter QuikShifter is offline
wow, I guess things heated-up here after my post, huh? Want some more spice? I also had a ported & polished head by then and maybe the GSR guy was a wimp or his car was tired or somthin', but I seemed to have better high-end pick-up than he did.
Old 03-10-2004, 11:09 PM
WindyIce's Avatar
WindyIce WindyIce is offline
Send a message via ICQ to WindyIce Send a message via AIM to WindyIce
very true
The formulas make sense. They are true!
**!!4thgen in the projects!!**
B16A LSD JDM With Entire Car
Old 12-02-2004, 09:59 AM
InEdAb20vtech's Avatar
InEdAb20vtech InEdAb20vtech is offline
Send a message via AIM to InEdAb20vtech
You both are right in your own way. Back pressure is essential for keeping tourque. It helps the burn at low revs by leaving small amounts of burning mix in the cyclinder to accelerate the burn of the incoming mix. Higher flow pipes are great for high rev hp. It helps with scavaging exhaust gas from the cylinders. You need a balance between the two to get optimal results for daily aggressive driving. The car will run without any exhaust piping but will be very annemic with a low rev launch in the residential as well as be loud enough to get you ticketed in a heartbeat if a cop sees you doing it. Besides the ticket for the noise you will get ticketed for not having a cat. That has a heavy fine and all but if you are caught with a gutted or disabled cat, you will be paying for the cops daughter to go to college and in some states they will take the car as well. A cat doesn't restrict the exhaust flow enough to make more than a 1-2% power loss and if you need that back then get a high flow cat but for geeps sake, use a cat if you're going to be on the street.
Anyway, quit fighting over bs like whos the noob and go drive. That's what is about really anyway.
Now back to the original issue of speed limiters, rev limiters and gauges.....
For your gauges you might want to just pick up a set of reverse glows in a usdm layout. it's cheap and easy and will have your Mph on the outer face.
If you want to change the cut off point you need to change your ecu. Reasearch similar apps from other models ect. and their specs then compare them to the aftermarket chipped ones and pic the one that suits you. There is no one ecu that makes everything perfect in every car. It's like voting for a president. It's always picking from the lesser of too lessers.
Old 12-02-2004, 10:04 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Hey noob, quit bringing up dead threads.
Old 12-02-2004, 10:59 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
*brings up dead thread*
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
