Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 03-17-2004, 08:54 AM
speedyvic speedyvic is offline
Re: 86 crx si oxygen sensor
alright well that looks like the problem then. I know my step dad is an ASSHOLE!!! thanks for all of your help, I'll keep you updated.
Old 03-30-2004, 05:58 PM
alright, Im going to tear it down this weekend so is there anything else I need to know? besides the head gasket, could the head bolts be the problem? we used the old head bolts and I have heard that they can stretch. could it be a bad bottom end bearing? I just want to know what I am dealing with.
Old 03-30-2004, 10:12 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
i would not suspect teh bottom end for anything unless you are getting really low oil pressure and even then it's an entirely different job so i wouldn't worry about it, as far as head bolts i have read that they do cause problems (search the tech forum for a thread called "One time use head bolts?" or something like that) but i myself have had no problems with this and i have re&re'd my head twice now with the same bolts.
Edit: i found the link to that thread
http://www.automotiveforums.com/vbul...ght=head+bolts
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 03-30-2004, 11:22 PM
Damn your good! Thanks for finding that for me. I guess I am going to take the head off and hopefully fix the problem, so I'll keep you posted.
Old 04-02-2004, 03:18 AM
QuackerStacker's Avatar
QuackerStacker QuackerStacker is offline
i have used my head bolts many times but i have had one or two break from to much use
~Michael Alexander~
Old 04-15-2004, 07:18 PM
Condor Condor is offline
Send a message via ICQ to Condor
if it was a 1-wire universal boche )2 sensor, which it shold be for $40, you need to solder the wire, otherwise the impedance won't be right. It may or may not generate a code, but it will cause idle problems.
