Old 03-09-2005, 08:57 AM
castlecare castlecare is offline
Re: Re: Re: Re: Voyager low fuel light and chime
Originally Posted by hotrick21
I have been trying all kind of things as well. I want to try your solution. Is the fuel pump located inside the gas tank? How did you go about changing it?
Thanks.
It's an easy one to do- it's in the tank. Just wait till the tank is almost empty, place a jack under the tank with some sort of board to support it so you don't dent the tank, loosen the to bolts that hold the tank and lower the tank a few inches so everything is easy to get to and CAREFULLY remove the connectors and retainer ring and it's out. It only took less than an hour and no more ding,ding,ding. I purchased the ful pump at Auto Zone for $179.00 . The fuel filter hooks up at the tank so you might as well change it while you're there.
Old 03-09-2005, 08:51 PM
glemieux glemieux is offline
Talking Caravan Feul Light AND Chime SOLUTION ~~~~<~~(@
drive by MPG,not by the Feul Gauge......and install a 500 Watt or Better Stereo system....that's what I DID!
