#16
Re: Re: What is the best way to shift when racing?
See the graphic I posted? ... it asks for the redline point ofr a reason. On the stock-turboed MR2 graph I posted, the ideal shift point is around 5500 rpms. With my T3T4 turbo on the same engine my mathematical ideal shift point is beyond redline ... obviously I can't shift there. So my ideal shift point IS redline (7200 rpms). Quote:
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment |
#17
I see your point. I understand what you are trying to say. But it still doesent take into account the engine...where it cuts-off. Even though you shift at redline, you still may not be getting the most out of acceleration. You may actually be accelerating slower if you shift past peak power.
Hey, does anybody else have another opinion? This is kinda getting interesting.
![]() 2003 Honda Civic LX Mods: Bone Stock
#18
The formula I posted using the stock-turboed MR2 I got shift points:
1st --> 2nd = 6595 rpms 2nd --> 3rd = 5643 rpms 3rd --> 4th = 5595 rpms The calculator I posted from: http://www.bgsoflex.com/shifter.html Gave me: 1st --> 2nd = 6130 rpms 2nd --> 3rd = 5553 rpms 3rd --> 4th = 5524 rpms
#19
Just becuase "torque" falls off on a dyno sheet does not mean that is time to shift.
http://www.datsuns.com/Tech/whentoshift.htm
#20
Using the calculator, and if it says that shift way past redline, is not ideal. I still believe that its near peak power.
Each of us obviously have our own opinion on what the ideal shift point is. And it seems that none will give in to another. So lets leave it at that and see what other people think is the ideal shift point.
#21
mycivic, see my last post. We posted about the same time and I think you may have missed it.
I am offering you facts - from physics. It is your choice what to do with them. There are hundreds of sites out there that will back my statements. I have offered no opinions.
#22
I dont know what else to say...
I still cant see past why it has to be way past peak power when it starts to drop in the torque curve. Quote:
#23
Hey mycivic, think of it this way:
Think of maximum turque over and range of rpms ... not just the peak point. EXAMPLE: Let's say your engine+tranny make it's most power from 4000-5500 rpms. Let's say your peak TQ is at 4800 rpms. What if you shift at 4800 and your rpms drop to 2000 rpms?! UG.... You are not "in the power" for THAT gear. You want to shift when you drop down into the "meat" of the next gear. You want to keep your car in the max power range.
#24
#25
No worries man... we are all here to learn and your questions pushed me to learn more today.
Thank you for that.
#26
Same here.
#27
Slight "Disclaimer" to the individual that referred to the Lingenfelter site.
I just thought I should add this guys. (Quote from LPE) "When determining proper shift points it is also important to consider the safe operating speeds for your engine. Consult your owners manual or your engine builder when selecting shift points. Shifting after the redline or past the safe operating speed of the engine can result in premature engine wear or damage." I just thought I should get that out of the way. In the quest for that last .05 at the traps people tend to overlook this little gem of wisdom. |
#28
#29
THe way I understand it is you wait until the point when you shift you will be back in a higher toque/hp range. for instance, if you are at 5600 rpm and you upshift and now you are making less power that is bad, but then you hit the 6100 mark and your upshift will make you more power.
#30
fast
![]() CHECK OUT MY CARS HERE! drag1320neon and 209neon's babys < 209 neon finished!> |
