Old 02-18-2004, 02:15 PM
mjohn mjohn is offline
Re: Fuel Pressure Not Maintaining
get the fuel pressure regulator from lindertech.com
and it will be 99. with shipping $108.
I wish you well....
Old 02-20-2004, 02:30 PM
Dannk Dannk is offline
Re: Re: Fuel Pressure Not Maintaining
I wish you well....
I really don't think it's the regulator...because it is not leaking back to the tank via the return line...
There is a device on my fuel line near the filter that looks like an in-line check valve. Where is the check valve located? On the fuel pump or inline with the fuel line?
Old 02-20-2004, 05:06 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
in the tank as part of the sending unit
Old 02-22-2004, 04:20 PM
TRUCK IS FIXED!! Thanks for the advice. Turns out, it was the pulse dampener in the fuel tank. The internal line from the pump to the top of the tank fitting had a pin-sized hole in it. This was allowing fuel to leak into the tank internally causing my drop in pressure after the fuel pump stopped. $250 later I have a new pump and sending unit. I pulled the bed off to install the stuff. It was suprisingly easy!
Reading high fuel pressure (carbureted) caffeineaholic Caprice 16 09-25-2010 02:55 PM
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 06:32 PM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 09:09 AM
tropper 2.6 will not start bwktp Trooper | SLX | Bighorn | Wizard 0 06-11-2009 05:57 PM
97 Blazer low fuel pressure new pump stalls in gear ChevyFamily Problem Diagnosis 6 06-05-2009 06:12 PM
