Old 02-13-2004, 11:41 AM
95civicCX's Avatar
95civicCX 95civicCX is offline
Re: Thinking about leaving the Civic scene...
Have fun finding a cheap B16 head, then finding a "cheap" mechanic to put the head on.
95 Honda Civic CX
SOHC VTEC
AEM High Flow Fuel Rail
B&M Adj. Fuel Pressure Modifier
B&M Fuel Pressure Guage
APEXi Exhuast
Del Sol Shifter
B&M Shift Stabilizer
H&R Race Springs
KYB AGX Adj. Struts
Eibach Pro Control Front Strut Bar
Arospeed Rear Upper and Lower Strut and Tie Bars
26mm Sway Bar
Rear Disc Brake Conversion (4 Tony)
Specialty Products Adj. Camber Kit
16 Inch Quantum Tec Alloys
215/40 Nitto 450
Old 02-13-2004, 05:28 PM
Kinked210's Avatar
Kinked210 Kinked210 is offline
Send a message via MSN to Kinked210
Yeah it might be kinda hard to find the head...but I don't need to find a mechanic...
Doesn't matter...a stock Integra DOHC would roast my crappy lil Civic
1996 Honda Civic Ex
D16Y8[SOHC VTEC]; 5-spd
AEM Short Ram Intake
DC Sports 4:2:1 Header
Tsudo N-1 Midpipe
Old 02-13-2004, 05:39 PM
95civicCX's Avatar
You gonna do it yourself? I think not. At least not with some of the questions that you've asked on here.
About the stock integra DOHC (find a stock SOHC integra for me, please) beating the "crappy lil civic... I think your wrong! My civic beats a couple of my buddies' not stock "DOHC integra's". Maybe I have the only civic that can do that. I must be fast!
Anyway, go get your integra and be happy with it.
95 Honda Civic CX
SOHC VTEC
APEXi Exhuast
Del Sol Shifter
H&R Race Springs
KYB AGX Adj. Struts
26mm Sway Bar
215/40 Nitto 450
Old 02-13-2004, 07:49 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: Thinking about leaving the Civic scene...
Originally Posted by 90LShatch
plus i dont trust the reliablity of ls/vtec but thats just me and ls/vtec is expensive when it comes to machining .
You don't know alot about LSvtecs do you? Just some bullshit you heard on superhonda.com huh?
I think the "power" that your feeling with your buddies integra would be torque from the DOHC.
DOHC does NOT mean it has torque, look at hte B16A.
Old 02-13-2004, 09:35 PM
Kinked210's Avatar
@95civiccx:
-No I'm not going to do it myself....what I meant was I have someone thats gonna do it..
I never said there was a SOHC teg....I said 'Integra DOHC' putting emphasis that teg's are DOHC and my civic is a SOHC...you don't have to be such an ass...
and i will have fun with my teg...and after the ls/vtec conversion id smoke ur ass any day mwa ha ha
1996 Honda Civic Ex
Tsudo N-1 Midpipe
Old 02-14-2004, 01:02 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Kinked210 don't talk shit to other people man, especially when you clearly know very little about motors other than what you've read. Ever since you've been here you've been practically busting juice all over your keyboard about getting a civic and doing and engine swap and doing up your motor. And now you want to sell your car for something older that you're going to most likely have to put a lot more $ into it to fix it up? Do you really think that it's that expensive to work with what you've got now? Slap a damn greddy turbo kit on that sohc $2000 or less; depending on what parts you need other than the turbo kit. But go buy your teg and come on here and whine a little more when you realize you don't want the teg anymore or you blow your motor up when you do a ls/vtec swap and don't know how to maintain it.
Old 02-14-2004, 04:02 PM
95civicCX's Avatar
Originally Posted by jcrx
DOHC does NOT mean it has torque, look at the B16A.
I would have to say that yes, DOHC does mean more torque when comparing it to a SOHC motor. Thanks for the input though.
Why put emphasis on DOHC integra when there isn't a SOHC version?...Just me.
Put more emphasis on the AFTER the ls/vtec conversion.....If your gonna talk shit about that.....
95 Honda Civic CX
SOHC VTEC
APEXi Exhuast
Del Sol Shifter
H&R Race Springs
KYB AGX Adj. Struts
26mm Sway Bar
215/40 Nitto 450
Old 02-14-2004, 05:02 PM
Re: Re: Re: Thinking about leaving the Civic scene...
You're a fucktard and know jackshit Thanks for your input. Just because a motor is DOHC DOES NOT mean it has more torque, and few of those that do are not so far behind that it is going to makes difference. The difference is the Hp that a DOHC is capable of. Have a look at some motor specs and you'll notice that in similar displacement ( the real reason for torque) motors, the torque is very close, while the Hp on the DOHC's is much larger.
For instance the B16A and the D16Z6
B16A 160hp and 111 lbs-ft
D16Z6 125hp and 106 lbs-ft
And this pattern pretty much repeats it self down the line, so if you're done trying to sound like you know what you're talking about, could you go bash your head in a door?
Old 02-14-2004, 05:17 PM
95civicCX's Avatar
Where did a b16 get mentioned in the convo, other than where you came in "fucktard". The DOHC that we were speaking of would be the b18a1 as a matter of fact "fucktard". So, don't jump into a convo that you don't know about. Thanks "fucktard". Anyway, would you like to post the stats on the torque of the b18a1 and show me that it doesn't have more than the d16z6 or any other d16 for that matter. If you could do that for me and then shut the fuck up, it would be greatly appreciated.
Thanks
FUCKTARD
95 Honda Civic CX
SOHC VTEC
APEXi Exhuast
Del Sol Shifter
H&R Race Springs
KYB AGX Adj. Struts
26mm Sway Bar
215/40 Nitto 450
Old 02-14-2004, 05:20 PM
Thanks
FUCKTARD
Hahahaha, look mommy, the little faggot got his feelings hurt because he is a dumbass, and doesn't know what the fuck he is talking about, hahahahahahahahahahahahaha....breath.....hahahahah ahahahahahahahahahahaha
You are a dumbass, and I was showing you that you are wrong, sorry you can't take critisizm.
Displacement, affects torque dipshit, there is no way around it, not DOHC, displacement, loser.
Old 02-14-2004, 05:36 PM
Here let me illustrate again, so your feeble mind can grasp it...
B18A1 DOHC 121 lbs-ft 140hp
F22B1 SOHC 147 lbs-ft 145hp
Are you getting this, is it sinking into your thick skull yet, or should I go on?
Old 02-14-2004, 06:09 PM
95civicCX's Avatar
Again, stupid fuck. One motor that was being talked about compared to yet another motor that wasn't fucking brought up until you brought it up.
Torque Differences in the
d16z6
b18a1
Those are the ones you need to list, otherwise just shut the fuck up.
95 Honda Civic CX
SOHC VTEC
APEXi Exhuast
Del Sol Shifter
H&R Race Springs
KYB AGX Adj. Struts
26mm Sway Bar
215/40 Nitto 450
Old 02-14-2004, 06:18 PM
Z6 106 lbs-ft 125hp
A1 140 lbs-ft 140hp
1.8 to 1.6, hmmmm.. more displacement = more torque?, no way?
Here's some more for you..
D16A3 1590 118 hp 103 lbs-ft DOHC
D16A6 1590 108hp 100lbs-ft SOHC
Amazing huh, same displacement, yet for some reason they have almost the same torque, but what? The DOHC makes more horsies, oh no, mister Bill!!!!!!!!!!!
Old 02-14-2004, 06:22 PM
Is that not enough for you? Have a gander at this...
D16A8/9 1595 137hp 108 lbs-ft dohc
D16Y5 1590 115hp 104 lbs-ft sohc
Wow, look at those torque numbers, hmmm... get what I am saying.
Sorry if I am being a dick, but bench tuners are annoying, and spread a bunch of bullshit that gets real fucking old after a while.
And there is a lot more to power output than DOHC, or torque, compression, bore and stroke, cam and ignition timing, fuel mapping intake exhaust manifold, and port design, vlave size, and on, and on, and on....
Old 02-14-2004, 07:33 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
I am so sick of people coming in here and talking like know crap when they don't know sh*t...First of all
The 1986-1989 Acura Integra came with a SOHC D-series motor. THERE IS A STOCK SOHC INTEGRA!!! The 1986-1987 USDM Integras came with a D16A1, the 1988-1989 Intgeras came with a D16A3. As I said, the 1986-1989 Integras' were SOHC, so sqaush the sh*t.
I am so sick of the ignorance of some people on here, it's ridiculous. Don't come in here and start crap when you don't know what you are talking about.
You asked WHY jcrx was throwing around other engine codes? The SAME REASON I mentioned the codes of the 1986-1989 Integra...THEY ARE RELAVANT TO THE DISSCUSSION AT HAND!!!! The point he was making is this. There is no replacement for displacement. Greater displacment = greater torque. That's why the 1.8 liter motors have MORE DISPLACEMENT than the 1.6 liter motors. Airflow does make a difference to a certain extent, there are other numbers too, but that's small numbers there. The big determaining factor in a stock motor's torque is Displacement. That's the point he's making. Where do you think the age old saying "there is no replacement for displacement comes from."? How do you think FI works when creating more HP and Torque? Same thing... B18B1 running at 14.7psi is forcing TWICE as much air into each cylinder, effectivly meaning the 1.8 liter motor is receiving the same airflow as a motor twice the size, 3.6 liter motor, would n/a. You are effectivly increasing the displacement of the motor, in terms of airflow, with FI...the result...more power and torque. This is how it works, it's the laws of physics. Displacement creates torque. This holds true if it's sohc, dohc...it doesn't matter....the reason for the increased power and torque with a FI motor is displacment (in terms of airflow), the same reason an H22 motor has more torque than a B18 motor, which will have greater torque than a B16 motor....or a D16 motor..etc.
