Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 05-03-2004, 01:01 PM
EHillinger EHillinger is offline
Re: Car jerks when coasting
I have a 2003 Passat GLX 4Motion wagon with the type of symptoms similar to what you are describing. After being told that it just works that way, I pointed my dealer to this thread and others like it, and I just received the following message"
". . . we will certainly take another look at your transmission, but my suspicion is that there may be nothing for us to do at this time. This transmission concern is a common one for the Passat -- I would say that we get at least one complaint about it per day. VW has issued some software upgrades for the Transmission Control Module to try and address it -- we will check and see if your car has the most current software. Unforutnately these software upgrades have yet to solve the issue completely, although they have been successful in reducing the rate of occurrence. VW is well aware of the problem and the level of frustration it can create -- they are working on further software upgrades to attempt to resolve it completely."
Ellis Hillinger
Seattle WA
Old 05-03-2004, 04:44 PM
mira8964 mira8964 is offline
Re: Re: Re: Car jerks when coasting
Originally Posted by mira8964
Update 5/1/04
I am picking up our 2004 Passat GLX from the dealership this morning. The dealership reluctantly replaced the Transmission Control Module (TCM). This a temporrary fix (bandaid) for lack of a better term. My dealer said to expect the bumping to return in about 2,000 miles. VW does not have a permanent fix at this time. Dealer said he hoped the fix would be in before the bumping starts again.
The permanent tip/fix software release date is a grey area for the dealership. VW will not commit to a firm date, only stated (through my dealer rep) that they are well aware of the problem and are finalizing the permanent fix.
For all VW tiptronic owners with this bumping/lurching problem when coasting to a stop > Pressure your dealerhip for a firm date on the sofware fix. We need our cars fixed now!
The dealer replaced the TCM (Transmission Control Module) this past Friday. The bumping/lurching went away. The car downshifts completely normal with no bump whatsoever. Bad news > my dealer said the new TCM will start doing the same thing after about 2000 miles. I'll bring it back for a new module again when this happens until the permanent fix is in.
VW is working on the permanent fix, but obviously not working hard enough. My dealer says the permanent fix could be 2days or 2months away, VW would not say.
Pressure your dealer to install a new TCM. CAll VW customer care and complain that VW is not working fast enought on the tip/fix.
Good luck
Old 05-03-2004, 04:46 PM
Ellis Hillinger
Seattle WA
Read my reply below. I thought I posted to you but ended up on my own posting.
Old 05-18-2004, 09:59 AM
bartbg bartbg is offline
Originally Posted by mapbabe
Check out this web page... there are plenty more of us out there.
http://forums.vwvortex.com/zerothrea...&cmd=addnotify
There are more folks talking about this on the same site under "Mystery Transmission Clunk"
Frankly it sounds like a case for a class action law suit. Something has to be done. Any thoughts?
I would be the first to join the lawsuit. Are there any lawyers in the house? I have a 2004 Passat GLX 4-motion with the same damn clanking problem. In traffic it can be very severe and does in fact feel like you are getting bumped from behind. The transmission goes from 1st to Neutral and Slams into 2nd. And they say it is not doing anything to the transmission. My dealer is a real SOB and is telling me this is "normal" and is due to the sporty transmission. It is a total crock -- let's do something about it. This problem started the first week I owned the car.
Old 07-05-2004, 11:38 AM
SwagThing SwagThing is offline
Angry Passat "Clunking"
I am here to tell you that this problem does NOT go away after 8000 miles. I have about 15,000 miles on the car (2004 Passat GLX Tiptronic), and it is still clunking away when coming to a stop. On my first visit to the service department they told me it was electrical and would be fine after my ABS light (which had mysteriously turned on) was readjusted. Well, it gave me a nice jolt on my very first stop light out of the dealership.
I am extremely upset. I was so looking forward to this vehicle--and I love it except for this one issue. Please advise me on what you all have done! I am going to bring the car back in, but after reading your horror stories I am certain it will do no good.
-Missing my old Honda in VA
Old 07-06-2004, 06:32 PM
simoneves simoneves is offline
Is the TCM update for 2004 only?
I have a 2003 4motion wagon, which suffered from the "rear-ended" clunk three or four times when it was young, but it has not happened since (now 19 months old, 15700 miles). It still changes jerkily at times, however, particularly as you slow to a halt.
My wife's friend has a 2004 model, which suffered from the clunk much worse, and last week they had the TCM software update installed, which has apparently fixed the problem and also made their transmission smoother to shift at any speed.
The dealer (the same one) claims that the fix they have in now is only for 2004 cars, and is not compatible with ours, but the implication from earlier posts in this thread (and others on other forums) is that it works on older cars too.
Anyone out there with a 2003 that's had the fix successfully?
Also, is it a flash update done through the diagnostic port, or does it actually involve changing the hardware (again, as implied by earlier posts)?
Many thanks in advance,
Simon
Old 11-12-2004, 11:01 AM
Also, I have since had the TCM replaced, which worked great for 3 days!!! Now it's back to the same old bumping. I will being following my state's lemon laws now...What a Pain. I will never buy VW again nor would I be happy with a new Passat, this happens to all the VW Passats with 4-Motion. There was a recent CNN article ranking the 2004 Passat 4-Motion as the car with the most customer complaints.
Old 11-12-2004, 02:39 PM
1danec 1danec is offline
the TCM fix worked for me, but I have only put about 2000 miles since the fix 5 months ago
Old 01-11-2005, 02:26 PM
dcosentino dcosentino is offline
transmisssion/jolt
I am experiencing the same things w/ my new 2004 passat v6 - i feel a jolt just before i stop- took to dealer with no results - don't know what to do?
Old 01-21-2005, 09:56 PM
VWinCA VWinCA is offline
Re: transmisssion/jolt
I have a 2004 Passat v6 with about 4k miles. Just took it to the dealer yesterday (1/20/05) to resolve the "harsh downshift / bumping issue." They were well aware of the issue and ended up re-programming the TCM. The fix code that they referenced on the service paperwork is:
FC: 3730400001
Perhaps this references the new software fix somehow?
In any case, the new software has definitely resolved the problem for now.
Some folks say that they have had the issue return but those are older posts so maybe it wasn't the same fix. Is the transmission "adaptive" in nature? Does it make adjustments to its own shifting patterns over time based on experience? Don't know but I will monitor over time.
Get the fix. I can say for sure that it works at least in the short run.
Old 01-22-2005, 04:17 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
For all you people having the jerking problem when coming to a stop or slowing down!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THERE IS AN UPDATE FOR ALL 2004 PASSAT V6 AUTOMATIC TRANSMISSION cars with this problem. VW will do a free update on the TCM that fixes this problem. ALL VW dealers should have an update cd that fixes this. There is a technical bulletin for this.
The new TCM has the new updated software that the update cd does.
Old 01-22-2005, 05:30 PM
Hey Veedubmechanic...
Do you know if the TCM software update is tied into the fuel gauge / trip computer in some way? Seems like since my update the other day, the trip computer on my v6 GLX has become much more accurate too.
Before, the fuel indicator would show "empty" and the trip computer would show "0" miles to empty but the fuel tank would only fill with about 13 gallons (its capacity is supposedly 16.4 gallons). Since the TCM update, it seems like the "miles to empty" calculations have become more generous.
Perhaps it's just my imagination...
Old 01-23-2005, 09:34 PM
VDUBMAN
If i remember correctly it just changes the shift pattern and how long the solenoid valves open. I dont think it has anything to do with the fuel guage. Also it has a miles to empty set to a level where you still have fuel left for those people who like to drive to empty.
