Old 02-09-2004, 03:17 PM
okie-chevy-man okie-chevy-man is offline
Banned
Send a message via MSN to okie-chevy-man Send a message via Yahoo to okie-chevy-man
mine is an LS. i have 2 plugs for trialers, the 8 pole and another round reciever. i also have trailer brakes.
Old 02-09-2004, 03:56 PM
Powerwagontim Powerwagontim is offline
Re: Transmission temp gauge
Did the trailer brake controler come from the factory? I am about to add in a 7 pin trailer plug. Is your 8 pin also factory? if it is, I would be interested in seing a picture of how it is done. Any chance of that?
Thanks, Tim
Old 02-11-2004, 10:22 AM
huminski's Avatar
huminski huminski is offline
I have the tow package on my 04. I have the tranny cooler, hi cap air cleaner, hitch and plug but no trans temp gauge. Mine is a LS.
Steve
2004 2WD 5.3 Xcab StepSide
Old 02-11-2004, 11:13 AM
Banned
i wonder if it is because you have a 5.3.
Old 02-12-2004, 12:30 PM
PipeDreamsMarine PipeDreamsMarine is offline
I have a 02 1500HD with the towing package and it has the gauge
Old 02-12-2004, 01:28 PM
bim's Avatar
bim bim is offline
Send a message via Yahoo to bim
Originally Posted by Powerwagontim
Hi again,
Well, I installed the gauge cluster today. What was GM thinking when they went to all the effort to install the sensors and all of the wiring but stopped short of actually giving us the gauge? That has to be the easiest mod I have ever done. As you said, slowprocess, its plug and play. I had a second Chevy dealed tell me if I installed the new cluster the truck would start, run ten seconds and quit, not to run again until the computer was reprogrammed. He was also wrong. What is with these dealers?
I have a transmission oil cooler coming next week. I will plumb it in series with the radiator cooler. Does it matter which cooler gets the oil first?
Thanks, Tim
Tim I' have put in many tranny cooler on different cars and I have always put the additional cooler after the radiator. The reason I do this is because if you cool the tranny fluid down with the external cooler and then send it into a hot radiator you are cooling the fluid down, and then heating it back up. Also when you mount the external cooler don't zip tie it to the radiator, instead I make brackets from metal and attach it to the upright supports, this way you get more efficient cooling. I also prefer to bend hard lines and only use hose to connect from the cooler to the hard lines. If you need any further info please ask
2002 1500 Ext Cab w/ 5.3L. Modifications coming...
Old 02-13-2004, 12:36 PM
radioralph radioralph is offline
I would like to buy JUST the transmission temp gauge for my 2000 Silverado with 5.3....local dealer says unavabile...ANY IDEAS? thank you, Ralph
Old 02-13-2004, 01:45 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
The dealer is correct...if you don't replace the gauge cluster you will need to buy an aftermarket gauge from someone like Dakota http://www.dakotadigital.com/product...category93.htm
don't forget you will need to get a sensor also.
Sonny
Old 02-14-2004, 10:18 AM
Jeremy-WI Jeremy-WI is offline
I wonder if there isn't a way to use the factory trans temp sender without affecting the PCM, although the sending unit from dakota might fit in the pressure test port on a 4L60e
Old 02-17-2004, 05:48 PM
MSpring MSpring is offline
Has anyone done the gauge upgrade mod on a 96-99 bodystyle before?
1996 G.M.C 5.7 with a 460E tranny.
Old 02-17-2004, 09:00 PM
MSpring, was just looking at the schematic for the 96 instrument cluster and it appears that there is no wiring for the trans temp guage, although an aftermarket guage and sender will work
Old 02-19-2004, 10:14 AM
can you install a temp gauge on a L460E without dropping the pan and drilling a hole for the sender?
Old 02-22-2004, 09:12 AM
LT-Z71drvr LT-Z71drvr is offline
I may be wrong, but I think the guage comes standard on trucks with the 4L80-E tranny. My uncle has an 02 2500 (not HD) and he has the guage.
What doesnt make sense is they put the sensor and wiring on the 4L60-E, but no guage. !!!!!
Go figure...
1996 K2500 Reg Cab Long Box
5.7 Vortec, HD 5-speed manual (NV4500)
LT265/75R16E Toyo Open Country M/T
Hypertech Power Programming (AWESOME)
K&N Air Filter, Flowmaster Exhaust
Centerforce Dual Friction Clutch
Pioneer Head Unit, MTX 200 Watt Amp, MTX 10" Thunder 4500 sub
"To be old and wise you must first be young and stupid"
Old 09-07-2004, 02:12 AM
silveradoman silveradoman is offline
I know a guy in Mexico that resets the odometers by the way...
Old 09-07-2004, 10:13 AM
Faze2183 Faze2183 is offline
Send a message via AIM to Faze2183 Send a message via Yahoo to Faze2183
ive read all this....and well ok.....when you got that new cluster did you install it ur self? did you have any kinda problems?
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
