Old 02-01-2004, 07:45 PM
houndsman houndsman is offline
Re: Perfomance problem?
Originally Posted by steventheseeker
It's a vortec 4.3l V6. It starts ok, not great. THe major problem is when it idles while I'm at a stop light. It shakes like crazy and I'm getting the worst gas mileage. I replaced the spark plugs and spark wires and it seemed to help. I just bought a o2 sensor and will replace it soon. Could it be my fuel injectors? I ran a cleaner through it helped a little. Thanks for your help?
My 94 Blazer is doing the same thing. Did you find out anything about yours?
Old 02-02-2004, 02:23 PM
mjohn mjohn is offline
Ok...
Old 02-03-2004, 06:24 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
It's the EGR... Driving around with a bad cat ended up clogging it most likely... Pull and clean the egr with carb cleaner and a stiff wire brush. (use a new gasket to put it back on). Make sure your pintle is clear of carbon and moving freely... Run seafoam through the engine to dislodge the major carbon deposits.. Check your plugs for signs of carbon build up.. (probably should do a general tuneup after the seafoam)
Old 02-05-2004, 01:02 PM
steventheseeker steventheseeker is offline
Hey Mjohn where did you get your CPI unit? Did you get it online? ALso some say that multi-port fuel injector and others say fuel injector(CPI) what's the difference? ALl i need is the CPI fuel injector, lines and the upper plenum gasket?
Thanks for all of your help. I called a mechanic place and they said that the vortec fuel injectors are know to go out and the whole fuel injector would cost 1,000-1200 just for the part itself.
Old 02-05-2004, 01:05 PM
rlith's Avatar
CPI was used from 92-95, CPI is CENTRAL PORT INJECTION, CMFI was from 96-current... CPI is a batch fired injection system (all cylinders fired at the same time) CMFI which in general is a close cousin to CPI is fired sequentially...
Old 02-05-2004, 01:12 PM
do I NEED THE FUEL PRESSURE REGULATOR IT SAYS THAT THE WHOLE FUEL INJECTOR COMES WITH IT BUT COSTS ABOUT $500?
Old 02-06-2004, 12:54 PM
steven...you can do much better $$ at rockauto.com...the CPI Unit is 288. with 2 day shipping...it came to $321.22 and it is a AC Delco unit...a very nice part...the CPI Unit contains the fuel pressure regulator...gmpartsdirect.com is another place for parts but, you must wait 8-10 days? I think this is right...
Steven...Best Wishes on the repair...you will save the $$ over time just on wasted gas...as now I get between 17-19mpg... :o)
Old 02-06-2004, 02:13 PM
rlith's Avatar
go to your Local Advance auto parts...275.00 and if it goes bad under warranty you can exchange it locally..That way you won't be out of a truck... Also no shipping charges...
Old 02-07-2004, 10:18 AM
seems you will be out sales tax tho...
Old 02-07-2004, 06:07 PM
rlith's Avatar
a couple of bux in sales tax, vs being without your truck for up to 2 weeks while you send the unit back to where you bought it from, they test it, and either send it back or send a new one? I'll take local every time.
Old 02-16-2004, 03:01 AM
I replaced my fuel injection and it wasn't that hard but I recently took it to get it smogged and my HC ppm at Idle failed. IT passed before I did anything to it so it must be something I did. I replaced my spark plugs and wires but drove them with the bad fuel injector for about a month could they hav went bad. Help please.
Also thank you so much for helping me with my fule injection truck is running great at my gas mileage has improved immensly.
Old 09-20-2004, 11:05 PM
jmeas jmeas is offline
with the way your blazer is acting it is the fuel injectors, the strong fuel smell is coming from either a leaking fuel line o-ring, or more likely the fuel regulator has gone bad, and it is on of the easiest things to replace yourself, if it is just the regulator, you can call http://www.totalauto.com they sell a repair kit for the reg, but if it is the injectors , when you take the old "spider" off just mark which hose goes where. Price wise cheapest i have found is http://store.getgmparts.com/fj10453.html, $210.
If the EGR valve is bad you will get a service engine light, code 32
Old 01-17-2005, 03:21 PM
sdp3501's Avatar
sdp3501 sdp3501 is offline
I just bought the CPI unit for my 92 S10 blazer. I got it from getgmparts.com. $225 with sipping (2Day Air) It came as a complete unit (spider) with a retaining clip and 2 "o" rings. I take it the "o" rings are for the incoming fuel lines, but I found a CPI "o" ring kit for 12 bucks at Orielly. What is this kit for? The poppets?
Old 01-17-2005, 03:27 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Perfomance problem?
Remember to replace the nut kit as well when you do the injector.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-17-2005, 03:38 PM
sdp3501's Avatar
Re: Re: Re: Perfomance problem?
Nut kit....What do I ask for at the parts store?
Upper plenum gasket. YES
Internal fuel lines????
Multi port "O" ring kit???
Nut Kit???
