Old 01-23-2004, 06:17 AM
comp comp is offline
????? recheck all connections,
Old 01-25-2004, 01:25 PM
nusch nusch is offline
Re: Need a little help
I checked all the connections but it still does the same thing. It sounds like it is the transmission because the engine seems to run perfectly now. I readjusted the throttle valve cable and the park/neutral switch but it didn't help. I am going to change the filter and fluid out of the transmission because it has been a little over 2 years since that has been done. I hope that works. Does anyone know of anything else I can do?
Old 01-25-2004, 03:07 PM
Brandon2350 Brandon2350 is offline
Re: Re: Need a little help
Buy a "For Sale" Sign...
Old 01-31-2004, 10:11 AM
old dawg's Avatar
old dawg old dawg is offline
I hope you've already fixed your shifting problem by now, but if not, you should check the trans electrical connector for corroded or loose pins, etc. This can certainly cause the intermittent shift problems you're having. You can disconnect it by squeezing the two pads on each side of the connector housing.
