| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#16
Re: Re: Pushrod vs. SOHC vs. DOHC
I believe there are some good engines of the ohc design and ohv design. They have both almost been around for an equal amount of time and they both have been shown to make amazing power when being clean enough for today low emission standards. The next big step will be cam less engines that will make both pushrod and ohc engines seem obselite
#18
OHV has been around much longer than OHC.
And Camless engines aren't that fantastic.
Mustangs are nice, but I'd rather have one of these...
#19
Note that SOHC and DOHC are both OHV just like push-rod engines. The engines which aren't OHV are the old side valve engines.
#20
yes, but I think the OHV in this case meant Cam in block.
#21
yup saabjohan please try to pay attention to the conversation. Push rod engines are generally refered to as ohv. As for the comment from mustang I'm not sure what you are baseing your oppinion on camless engines on. In theory they will blow everything else out of the water I'm interesting why you think they are that great especially seeing how I doubt you have diven one as they haven't been released yet. And acually ohc can be traced back to at least the 1920's so yes the both have been around a simalar amount of time
#22
That is true, that they have been aroud since the 20's, but Cam in block has been around since before the turn of the century.
Show me proof of the vast superiority of camless engines andI may just change my mind.
#24
Well its a little bit hard to show proof seeing how they haven't been mass produced yet how even in theory a camless engines should be able to alter the lift and duration for peek performance at any rpm and driving condition. It will be like vtec only 100 times better very good hp numbers should be able to be produced from even very small engines with exelent drivablity. Now of cource there will be teathing problems as with any new tecnology and I probably wouldn't want to buy one till they get it perfected but it should be quite amazing once they get it right
#25
saab everyone understood except for you
#26
Re: Re: Re: Pushrod vs. SOHC vs. DOHC
If I were to say a Honda engine used OHV, would your blood pressure rise?
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable. |
#28
Enginers have spent hundreds of years developing special terms and word usages to avoid confusion and allow the easy and efficant transfer of ideas, so when discussing things of a technical nature it pays to adhere to those terms. And since OHV Hondas have entered the conversation Im wondering if Ferrari, BMW and Honda have ever made a pushrod engine? They are generaly regarded as the three best engine builders in the world, proven by thier F1 success. (Note, Im excluding low production manufactors like Cosworth, as they normaly start with a mass produced engine design).
#29
yes SAAB was right.
using incorrect language, regardless how common, does not make it correct. any specs/info on the camless engine? who makes it?
#30
I believe alot of companies are running with the concept at the moment I know for sure gm is working on it and plans to have some engines using it in the not to distant future how ever it will require going to a higher voltage electrical systems for sure to supply the soliniods that will be used to open the valves
