Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-12-2004, 05:39 PM
ematrixLS ematrixLS is offline
Re: 'Check Engine' Light On Dashboard
I LOVE YOU, thankyou so much lol
Old 01-12-2004, 06:13 PM
JDMDB7 JDMDB7 is offline
Old 01-12-2004, 08:07 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
to find the "maintainance" reset button, pull ur seat all the way back so u have some room to get under the dash on the drivers side. look under the dash, not towards the firewall or any thing, but where the dash ends. it's more towards the right of the car. u'll see a whole bunch of wires, a fuse box, relays, etc. look for a black box with a BLUE button in it. the button is not pertruding out or anything, but is flush with the box. this is the button u gotta press.
Old 01-12-2004, 09:35 PM
xhundredproofx xhundredproofx is offline
wait wait wait...the thing JDMDB7 said....is that what I have to to?! ahh im comfused...
Old 01-12-2004, 09:55 PM
That's for resetting the "maintenence required" light, not the "check engine" light.
Old 01-12-2004, 10:05 PM
xhundredproofx to reset ur check engine light take out the 7.5 Amp BACK UP fuse from the fuse box under the hood for about 15 seconds. this will reset ur ECU. if u didnt fix the problem thats causing the CEL to come on then it will come on again after driving the car for a while.
Old 01-13-2004, 07:10 PM
smfitch smfitch is offline
Wire Trick
Does the wire trick to test the engine blink codes apply to all years and models? I've got a 2000 Acura Integra. What is something I could use to connect the wires and try this?
Old 01-13-2004, 08:55 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Wire Trick
Yes it will work for you too, try using a paperclip or a small spade connector that goes onto the end of a wire. Just anything that you can push into the socket and connect the two wires.
Old 01-14-2004, 07:01 PM
9 CEL long BLINKS
Can anyone help? I'm getting 9 (what seem to be long) blinks, then a pause, and it repeats. Can anyone help?
Old 01-14-2004, 07:15 PM
whtteg's Avatar
Umm try to do it againa nd see how many are long and how many are short b/c that would be a code 90 and that is not possible.
Old 01-15-2004, 07:19 PM
OKay
I tried it again. The CEL came on, blinked off briefly, then came back on...help?
Old 01-19-2004, 10:31 AM
Hey whats up, if you got 9 long blinks and no blinks after that then you got an error code 90, which is possible. this code means that you have an EVAP system leak detected in fuel tank area. i dont know how u would go about fix n this problem but look at the diagram of the EVAP system which is located on the underside of the hood. check all the hoses to make sure that their all connected to the EVAP canister and check to see if there are any holes in the hoses. if you can, raise ur car on jack stands and follow the hoses to the fuel tank to see if there are any leaks in the hoses that route from the EVAP canister to the fuel tank. if you found leaks in the hoses replace them and reset ur ECU to get rid of the Check Engine Light (CEL). u reset the ECU by taking out the 7.5 Amp "Back Up" fuse from the fuse box in the engine bay for about 15 seconds then put it back in. If you didnte fix the problem the CEL will come on again after drive n the car for a while.
I would take the car to a mechanic to see what they say. tell em that u think it's a EVAP system leak oki.
laterz
Old 02-11-2004, 01:10 AM
skylinedo skylinedo is offline
I get 6 short flashes then no flashes. Must mean problem #6, can anyone decode this?
Old 02-11-2004, 11:19 AM
the error code you have is that the ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor.
Old 02-11-2004, 04:16 PM
wickedplastikman wickedplastikman is offline
when i am driving my car, the check engine light will pop on and off occasionally. sometimes it will pop on, and then stay on. will this trick tell me what the problem is if the code is only coming on occasionally? i was thinking that it is an o2 sensor. if it wont work, can i drive until the light pops and check it with the car running?
99 teg ls turbo:
Drag gen III turbo, Blitz BOV, Blitz Boost Controller, AEM Standalone ECU, MSD Ignition, MSD Blaster SS Coil, MSD Cap, Skunk2 Intake Manifold, AEM Fuel Rail/Fuel Pressure Regulator, ACT XCT Clutch, ACT Aluminum Flywheel, Nex SS Coilovers, Thermal Stainless 3" Exhaust, Skunk2 Short Shifter/Knob, Rota 15" Black Slipstream Wheels, Falken Azenis Tires, Brembo Rotors, Axxis Metal Masters, Type R Wing/Seats, VIS Carbon Fiber Hood
