Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-11-2004, 09:54 PM
black89crxLs's Avatar
black89crxLs black89crxLs is offline
Send a message via AIM to black89crxLs Send a message via Yahoo to black89crxLs
Re: b16a vs ls
long gear....thats just a myth
  #17
Old 01-11-2004, 11:45 PM
Thepeug's Avatar
Thepeug Thepeug is offline
Quem queritis?
Send a message via AIM to Thepeug
If you really want to go turbo, forget both the GSR and the b16 and go with the b18b1. It's the sturdiest engine for turbo apps, plus it's cheaper than the other two. You're also right about the longer gear ratios on the LS tranny that would help spool the turbo, and the b18b1 can handle 10-12 psi on stock internals with most turbos. The B16 and B18c1 can typically handle only 6-8.
Peace, love, and premium octane.
  #18
Old 01-12-2004, 01:32 AM
XXXcrxXXX's Avatar
XXXcrxXXX XXXcrxXXX is offline
Banned
Re: b16a vs ls
yeah i am planning doing Ls swap next 1 or 2 years i'll go turbo then it should be around mid 12s
  #19
Old 01-12-2004, 02:34 PM
Re: b16a vs ls
like i sad, the long gear ratio of trannys is just a myth, a turbo will spool depending on the motor set up, and HP out put all depends on the power band, and turbo tuner knows this!!!!!!!!!!!!!!!
  #20
Old 01-13-2004, 01:41 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: b16a vs ls
Actually no, it isn't a myth, tranny gearing has everything to do with acceleration, powerband dictates hp output, not the other way around. If you take two B16A's and boost them with he exact same setup the one with the shorter gears is going to be faster.
Whatever, both of those motors are great for turbo applications, and will be much faster when built right. And LS's cost about the same as a B16A.
Old 01-13-2004, 05:11 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
the guy has been banned.
thread closed...
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
b16a lsd vs b16a non lsd 91blublaze Engineering/ Technical 16 10-14-2003 03:20 PM
JDM OBD-1 B16a head for sale, OBD-1 B16a engine harness for sale, GSR intake manifold CRXtc Engineering/ Technical 0 09-09-2003 10:23 AM
Turbo B16a VS Stroked B16a EF9JDM '88 - '91 Civic | CRX | Wagon | Shuttlee 28 09-03-2002 06:15 PM
b16a sir 1 vs. b16a sir 2 Mastashock13 Engineering/ Technical 7 01-16-2002 02:06 PM
Closed Thread
