Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 12-24-2001, 01:58 PM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
Well it looks like you dont want to read the info I posted. Instead you choose to repeat your blindsided remarks. This is not what this forum is about. If you dont have respect than please dont post here.
IF you READ what I posted you CAN use an earlier ECU on your car. You CAN have it reprogrammed to your engine specifics, no matter what your compression ratio is.
I never said for you to use a stock P10 ECU on your P11. I said you can use one of those but have it reprogrammed to your specific needs.
Please dont misquote me. ...and leave your know it all attitude somewhere else.
Old 12-24-2001, 02:15 PM
jprimera jprimera is offline
Hi
I believe that you lost the point b-boogie which I ask was if it were pocible to place the Ecu of p10 in p11 (without reprogrammmed) I believe that 1fast primera leave everything clear(is not pocible)), and nobody has needed the respect to you, 1fast primera express his point,and is right.And if you read the first post made for 1 fast primera ,he clarified everythig.
greetings
Happy X MAS
1998 PRIMERA GX 10.1 CR Chile.
Old 12-24-2001, 02:20 PM
b-b00gie's Avatar
Banned
OK, I didnt understand that in your intial post you wanted to keep a stock P10 ECU program. In that case no.
But I mentioned you can do it if you reprogram the ECU no matter what your compression ratio is. Thats all I was saying until he started taking me out of line.
Anyhow... happy holidays to you too
Old 12-24-2001, 02:37 PM
b-boogi wrote :But I mentioned you can do it if you reprogram the ECU no matter what your compression ratio is.
Shure, but you also said that de comprecion has nothing to do with it.(when I was refer to if were pocible to place the Ecu of p10 in a p11),and is here when you lost the point, because you said that the comprecion has nothing to do with it,and has much to do, 1 fast primera leave everything perfectly clear without isult you. He is a exelente person.
Now I think everythig is clear
Old 12-24-2001, 03:22 PM
1FastP11 1FastP11 is offline
I took you outtaline?
Whatever dude! I answered the question regarding the "once again and I hope this time your attitude can manage it" south american P11. That was the aim of the post on the first place. I'm leaving the subject now.
Peace and merry x-mas
Claudio
:smoka:
Claudio in Chile
'02 Nissan Primera GX
10:1 CR roller SR20DE with 7.25K rev limiter, JWT Roller S3, Custom HS G4 *EGRless*, HS CAI with Stillen POP, UR pulley 2 set, Crush bent 2.25" exhaust, WRX OEM muffler, Apexi Rev/speed meter blue screen. Best ET on track: [email protected] with a 2.4x sec 60'
Old 12-24-2001, 03:31 PM
b-b00gie's Avatar
Banned
Again the compression ratio and other things have nothing to do with it. You are not swapping to an early P10 ECU to keep the stock program. The point of swapping is to have JWT reprogram the ECU to your specifics. You cant do this with the late model ECUs.
That is exactly what I said. The compression ratio does not matter BECAUSE you can reprogram the earlier ECU.
If you keep the ECU in stock form yes its not a good idea.
1FastP11, yes you took me out of line by mis-quoting me, and then mocking me as if I was completely wrong.
I understand now that you were speaking of stock ECU's while I was speaking of a reprogrammed one. What I meant before (and still do) is that you can take an early model ECU and harness and reprogram the ECU to your needs.
I have a 2000 P11 w/ 9.5:1 CR and will be using a BB DET harness and ECU reprogrammed to fit my needs because I will lower the compression to 8.3:1.
Thats all I was stating from the very beginning.
Old 12-24-2001, 03:45 PM
b-boogie wrote :If you keep the ECU in stock form yes its not a good idea.
this was the principal idea ,1fastp11 and me were refer.
b-boggie wrote:.If you keep the ECU in stock form yes its not a good idea
yes ,we where talking about this,
b-boogie wrote:I understand now that you were speaking of stock ECU's while I was speaking of a
reprogrammed one.
ok .
no body mocking you .
You whrere speaking another thing.
gretings
Old 12-24-2001, 03:58 PM
b-b00gie's Avatar
Banned
:right:
Gear selector error and other ECU mysteries jarl Trans Sport 5 05-02-2010 06:33 AM
Flash ECU, will the car start without? schreib Rodeo | Passport | MU 1 03-15-2010 08:09 PM
Fool a OBD11 accord ecu into thinkn rear O2 is ok? cwoblong Engineering/ Technical 4 10-20-2003 04:13 PM
Wtb: 94-96 P10 Ecu ricecube77 Classifieds 2 05-02-2002 10:40 PM
Trading your P10 for my P11? G22DET Classifieds 15 07-17-2001 10:18 PM
