Old 01-07-2004, 04:20 PM
nates6969 nates6969 is offline
talon not running
Thanks a lot! Ya i bet i do just have a bad head gasket and warped head! The thing is the person who was drivng it at the time drove it almost out of oil which is when it started overheating and then also the coolant went and it was overheated to the point of shut down several times! errr! so ya I think im definitley gettting the head plained! its only 50bucks at a local shop and hes pretty good! so do you think I should worry about rings at all?? they look alright but do you think i should swap in a new pair while i can?
Old 01-07-2004, 04:36 PM
kjewer1 kjewer1 is offline
AF - Advisor
Well now... Based on this new information (or I didnt see it before perhaps) I would say dont bother putting that engine back together until you check the cylinders for wear, size, and roundness. Odds are at the very least you should rering it and hone it. If its out of round, size, or jsut worn/damamged then you may have to bore and hone, which will require pistons with matching oversize. In a nutshell, a basic rebuild. IT sucks bigtime, but its one of those things, do it right, do it once. If you get it all together and compression is still 120, you'll be wishing you were dead and drinking 40s until you puke for weeks, trust me If it was me, and I had some cash, I'd use it as an excuse to get a built short block if you plan to get nasty with the car someday... In any case, good luck with it. Try to use a good trustworthy machinist, and if you have any other questions, dont hesitate to post of course.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
car stops running after a while brenda_240 Cavalier Problem Diagnosis 8 10-25-2008 11:16 PM
98 passport idle shut down after 7o k of running after a computer reset 98hondapassportnyc Rodeo | Passport | MU 2 11-30-2007 10:29 AM
Starter keeps running after key in run or off salted Impala | Impala SS 2 07-17-2006 07:57 PM
First off, radiator hose busted gacouple Grand AM 0 12-13-2005 06:51 PM
89 Gmc Stops Running When You Stop wademcclung_8 Sierra 1 06-12-2005 06:29 AM
