#16
Vtec is my drug and I'm addicted to it!
3Geez Member Since: October 27, 2001 You want an Acura or a Vw? I can sell you a brand new one. I want a NSX and have to look at them all day. I need to sell whole bunch of cars to ever be able to afford one, so please help me out. :hehe: |
#17
I hit vtec at least once a day but i don't always redline. On a few occasions i have pinned the needle past the redline by accident(like the shifter banging into neutral and me flooring :+( car still ran good doing 8,000 rpms anyway. Other than that i just get it upto 6,000 or 7,000 when the mood strikes. Doesn't everyone just get that great feeling when vtec kicks in.
#18
i usually dont redline it. hey im cheap i dont want to waste gas
i usually shift from 3500-4000. depending if the road is an uphill or not |
#19
BAD DRIVERS
RED LINING IS FOR BAD DRIVERS THATS WHY YOU GUYS BUY MONSTER TACOS WITH SHIFT LIGHTS, YOU KNOW TO CHANGE THE GEAR AT THE GREATEST POWER POINT. I WOULD NOT BUY A CAR FROM YOU AND BY THE WAY WHILE YOUR CRUNCHING GEARS AND BLOWING SMOKE AND BOLTS OUT YOUR EXHAUTS IM 400M DOWN THE ROAD
#20
I seldom redline only when I need the speed or when I an racing, but vtec kicks in almost every day for me.
aem cai dc sport 4-2-1 headers apexi dunk exhaust aem power pullies car sound hi-flow cat |
#21
If you don't shift the prelude at redline when you up shift the revs will drop below the vtec change over. Besides the H22a make power well past the redline. These aren't chevys or fords here they are meant to be run hard.
#22
Re: BAD DRIVERS
Second, you're wrong about shifting at the greatest power point - you actually want the maximum power to be close to the the middle of each gear. The idea is to get the greatest average power in each gear. If you shift right at the peak hp point, you'll come way down off the power curve. In our small displacement, high RPM motors, peak hp is fairly close to the redline, and so the redline is the closest we can safely get to the ideal shift point. Third, I somewhat agree that a monster tach is overkill for a street car, but show me any professional racer without a large tach, much less a shift light, and I'll show you someone who blows motors and doesn't win much. Fourth, we don't kin much to rude people around here. If you have something constructive to say, then please by all means share it; but don't be insulting.
#23
every time i drive.
#24
Sorry
Peak power is around 6700rpm on average and redlining is falling way of the power curve, its actually about 600rpm to far as you start falling the wrong way. It would me more use changing at around 7000rpm to maintain high power from this gear and keeping it up in the next. Why flog your car when its not needed, maybe everyone needs some dyno time.
You also would not worry about falling of the vtec point if you had a vtec controller which brought the point back to where it is supposed to be. On my Chargedlude its now at 4400 rpm. |
#26
PPL
you can move the rev limiter and the vetc will rev smoothly to over 10,000 rpm :sun: the factory redline was initally put at 8500 to comply with jap regs. I rev to bout 9500 every day and my lude begs for more
#27
Also, since the reciprocating mass stress goes roughly as the square of the RPM, your getting about 65% more stress at 9500 than at the factory 7400. My guess is that you'll see a rod bolt failure pretty soon from the repetitive stress. Also, how did you remove the stock rev-limiter? Are you using an aftermarket ECU?
#28
Yo Fritz
Dead right My mistake of course the redline is at 7400 RPM . And with regard to Flow - Check out what the old one has to say about it. All you need http://www.theoldone.com/articles/h22a.head/ And if ya dont already kno it - chek http://www.hondata.com/ http://www.hondata.com/stage3.html Stage 3 modifications Speed limiter removed. Adjustable rev limiter. VTEC controller Shift light Launch control Full throttle shift Well Cool Mek
#29
So you have an Endyn or similar port job? What about the valve springs & cam? What about the rods? Which ECU did you use for the Hondata Stage 3 mod?
Please tell us about your mods - don't say you spin to 10k and then leave us hanging...
#30
We're talking about Honda here there redlines are far lower than need be. Honda is very conservitive in everything they do.
