Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-26-2003, 03:30 PM
rodtice's Avatar
rodtice rodtice is offline
Re: Noisey Serpintine belt
Tried the silicone trick today, as my belt also squealed when cold.
Quieted down so fast as I was spraying it almost scared me.
Old 12-26-2003, 04:51 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Re: Noisey Serpintine belt
If your belt is worn or hardend, the noise will return in a couple of days. I've never had a squeal problem and have always used Gates belts/hoses. I spray mine to keep it from drying out, as our local average humidity is 22%.
Quality isn't expensive, it's priceless.
Old 12-29-2003, 07:53 AM
Randy1 Randy1 is offline
I bought some silicone spray (Motorvator brand) from K-mart. I sprayed it on the
belt with it warmed up and running, sprayed it on there for a good min. then let it set
over night so it would soak in good. That was about a week ago and so far no sqeaks.
I will probably continue to use this silicone as needed until spring, then i want to change
the belt with one that won't squeak. Indy8, you say Gates belt won't harden and
and make noise. Do you know who sells the Gates brand belts? Thanks.
Old 12-30-2003, 01:24 AM
Indy8's Avatar
Let me re-phrase that. All rubber products eventually harden. In my experience, Gates last much longer than any other brand. I change all my vehicles belts once a year, regardless of need. It's cheap and easy. If you can't find a Gates seller, they make most of NAPA's belts and hoses. They will have an "ECR" sticker on them.
Old 12-31-2003, 12:21 AM
bustedratchet bustedratchet is offline
Re: Re: Re: Noisey Serpintine belt
Take it easy on the silicone. The next thread will be my A/C doesn't get cold. (If your lucky enough to live in a warm area) It's kinda funny when the compressor stays still while the rest of the pulleys are turning.
Old 04-27-2009, 09:35 AM
Rmtalavera Rmtalavera is offline
Tech Tip; Put a Bando belt on and this will fix the Issue. I have been a tech for 26 years. If all the pulleys and the other items are in good shape this is the cure.
www.BandoUsa.com
Features & Benefits
Award Winning OEM Supplier–80 major O.E. Quality Awards since 1989
(GM, Mazda, Toyota, Subaru, Mitsubishi, Honda, Nissan, Isuzu & VW)
3RD Largest Manufacturer of Automotive Drive Belts in the World
V-Belts: Molded notch design for extra flexibility and reduced heat build up, providing a long belt life.
Serpentine Belts:
* Bando serpentine belts are precision ground two times to insure adherence to manufacturer’s specification.
* V-ribbed belts are precision engineered for a long life under all conditions.
* Serpentine belts are made with EPDM rubber which is more heat resistant and longer lasting than other types of rubber.
* Bando belts are fiber loaded to provide for quiet operation through the life of the belt.
*Bando serpentine belts have a canvas top cover for longer life and greater durability.
* Bando only has one line of belts – for both OEM applications and the aftermarket. The same belt which the manufacturer specifies is the same belt for replacement
Serpintine Belt Mad_Reilly Cherokee 4 10-09-2004 10:34 AM
serpintine belt replacement brittfan Contour 1 08-27-2004 11:45 AM
97' Monte Serpintine Belt Installation MeanMonte31 Monte Carlo 1 08-18-2004 07:50 PM
Serpintine belt ant256 Grand AM 1 05-12-2004 12:15 PM
Bolt snapping off that holds serpintine belt on. kbh29 Corolla/Matrix/Voltz 2 04-03-2004 05:19 PM
