Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-27-2004, 11:32 AM
Ramblin Fever Ramblin Fever is offline
Re: Re: Rodeo burns oil.
Drain it out! At least I would, I learned that the hard way. I have the older model, which is not an oil burner, and upon moving back to Colorado had a hard time coming up with time to do my own change. So I took it to the dealer, sure enough same thing as you. Only I didn't feel I should "need" to recheck their work, so I didn't. Two weeks later when I started seeing oil drops, figured I'd better check the oil and find the leak.
Long story short, had almost a full qt extra and she popped a valve cover gasket - which may have been going anyway. But I will NEVER again have anyone else do my oil.
I think the possibilities that can happen are foaming and blowing a seal/gasket from the pressure. I would not take the chance - it'll be much less $$$ to just check that oil often.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-27-2004, 12:05 PM
amigo-2k amigo-2k is offline
Isuzu Guy
yup that extra qt of oil is a bad thing. crack the drain plug and drain out the extra.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-27-2004, 02:14 PM
95.5 Rodeo's Avatar
95.5 Rodeo 95.5 Rodeo is offline
In addition to everything else that has been said concerning oil burning / leakage, I'd like to put valve guide seals on the list. Like any rubber exposed to oil and heat, they age and harden. I can tell mine don't seal like they should. If the Rodeo has been sitting for a few days or more, I can smell oil burning on startup- then it goes away. When the common chamber (plenum) was removed, I could see oil glistening on the valve stems and with 24 total valves on the engine, I'm sure it adds to the problem.
Just my 2 cents...
Dale
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 09:39 PM
