| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
| Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
Show Printable Version | Email this Page |
#16 | ||
Honda God
Re: Re: b18a1 vs b18b1
Also, here is the info on the gearing for the trannies of the b18B1 and B18A1..the B18B1 tranny has a more turbo friendly final drive ratio... B18B1: Hydraulic (S80) Gear Ratios: 1st: 3.230 2nd:1.900 3rd:1.269 4th: 0.966 5th:0.714 Reverse:3.000 Final Drive:4.266 B18A1: Cable (S1/YS1) Gear Ratios: 1st:3.166 2nd:1.857 3rd:1.259 4th:0.935 5th:0.742 Reverse:3.000 Final Drive:4.400 for future reference, here's a site with that info... http://www.allmotorhonda.com/techpag...anny_specs.htm |
#17 | |
Banned
Re: b18a1 vs b18b1
thanks for the infor but what is differnt between cable tranny and hydro tranny? Which one is better? what hydro trannys do? what cable trannys do?
#18 | |
![]() Join Date: Jan 2002
hydro/cable is just the way the clutch is operated, in a car with a cable clutch, a cable is hooked on the throw out arem and the pedal and the pedal pulls the throw out arm, and in a hydraulic clutch the pedal pushes fluid through thje libne and pushes on tyhe throw out arm disengagig the clutch. which one is better depends on what car you got, and what gearing you prefer.
current -84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex history: -01 R1-04 daytona 600-94 teg RS-95 teg LS -91 teg RS-92 teg GSR-94 civic CX hatch (3 times) -94 civic DX-96 civic HX-97 Accord LX-72 superbeetle -74 beetle-84 silverado-66 c10-74 maverick-78 280z -84 200sx-86 tercel wagon-95 mustang V6 |
#19 | |
Banned
Re: b18a1 vs b18b1
oh...so which one is last longer? and which one is more expensive to fix when It's broken..
#20 | |
Banned
Re: b18a1 vs b18b1
and for the cable tranny..when ever I shift into the 2nd gear than I heard the crack sound.so what's up?? I heard my friends said that it's hard to fix and cost a little money..but It still runs..so I just want to know what's wrong with my cable tranny...the crack sounds very loud...also when i try to shift to the 2nd gear...the stick pushes back ..
#21 | |
well, you are putting this in a CRX so id go cable. and im sure either trans is expensive to fix, cable or hydro. but if your getting a B18B swap its coming with a hydro tranny, if your getting the A1 swap then its coming with cable. maybe this shop[ has lots of stuff already there and you can get the B18B1 and have him bolt it up to a cable tranny so youll have the morre power and the trans meant for the clutch setup you already got.
#22 | |
Banned
Re: b18a1 vs b18b1
cool..so which means that B18b with cable tranny more powerful than B18b1 hydro tranny in Crx?
#23 | |
sure.....
#24 | ||
Honda God
#25 | |
Re: b18a1 vs b18b1
i swear eckoman...you talk and i listen. if youd double the amount of posts you make, wed all be twice as knowledgable. i know the last post was repeated info, but still very informative. thanks.
1997 Honda Prelude Base 18G Turbo - 8 Psi GReddy EVO Catback 1995 Honda Civic LX Bone Friggin' Stock |
#26 | ||
Honda God
#27 | |
Re: b18a1 vs b18b1
if your gonna pay that much for an engine ecu and axle your crazy and i would hope its almost branew i couldnt imagen 3000 dollars lord liftern
#28 | |
Honda God
Re: b18a1 vs b18b1
You do know this thread is a 6 year old thread from 2003, correct?? Even if the pricing numbers the member gave were high (which it did sound high, even for the time, I agree), keep in mind prices have changed in the last 6 years for b-series, especially with the advent of K-series swaps cutting into demand.
![]() ![]() It's just that easy folks... mind the forum guidelines and we're cool. Empty Pockets Racing Member #6 EPR Member 4 Life |
