Old 01-07-2004, 12:50 AM
97blazerct's Avatar
97blazerct 97blazerct is offline
Send a message via AIM to 97blazerct
Re: 97 blaxer
Originally Posted by gurcz44
I have a 97 blazer that is on it's 3rd trans, 3rd heater core, 3rd gas guage, 2nd fuel pump, and is in the shop right now for the trans again. This time they said it was an electrial problem...that the sending switch is not sending the right info to the trans so it defaults to 3rd gear...Thankfully, I purchased major guard the 2nd time we went back for repairs (it was stll covered on the 90 day dealer at the time)
THANK YOU!!!!!!!!!!!!!!!!!!!!!!! i always do that, it seems.
fords.. drive a chevy
My 1997 Chevrolet Blazer LS 4x4:
http://www.sounddomain.com/id/chevy4x4girl
Check out the pictures of her! Sign the guestbook and rate her good!
Old 01-07-2004, 12:51 AM
97blazerct's Avatar
Re: 97 blazer needs trans already
Originally Posted by trannyman52
when this transmission 4L60E suddenly looses reverse// the sun-shell
has broken//stripped ect/ect.It's the weakest component in that
transmission. Should also loose O/D..
To solve this problem// a person should come to a complete stop WHEN
shifting from rev to drive /// drive to rev. Now the sun-shell is NOT
subject to the shearing force that causes it to break!!!!
The part is a piece of crap/// but that bit of caution will keep you out of the repair shop!!!
i dislike foreign cars
Old 01-08-2004, 09:51 PM
dxrflyboy dxrflyboy is offline
A heater core can either plug up or leak. If it leaks, you will smell antifreeze in the car and it will fog up the windshield. If it plugs up, you will have no heat. But there are other things that can cause a no heat problem, like a thermostat stuck open or a faulty heater blend door actuator.
Dan
Old 01-08-2004, 10:32 PM
97blazerct's Avatar
Re: Re: 97 blazer needs trans already
Dan
thanks ill look into those things..
