Old 12-14-2003, 01:12 PM
SaabJohan SaabJohan is offline
Re: Re: what does compression ratio mean?
Originally Posted by MustangRoadRacer
you can also prevent detonation without upping the octane by adjusting the timing, or cooling the intake/fuel. or both.
When using ignition timing to prevent knock this comes with the price of a powerloss and increase in fuel consumtion.
Old 12-14-2003, 03:46 PM
JohnnyWash1's Avatar
JohnnyWash1 JohnnyWash1 is offline
SJ, when you retard timing to prevent preignition, you are increasing fuel consumption? How so?
Jon
2000 Mustang GT [email protected] Exhaust
2000 Celica GTS 6-speed A very pathetic 16.5@88mph (could not shift into 2nd or 3rd) Intake
1994 Integra LS I/H/E
1990 Integra RS 16.6@85mph Intake
Old 12-16-2003, 12:34 AM
Jon
The efficiency of the engine drops. When timing is advanced we get a higher combustion pressure and higher efficiency. It's the lower combustion pressure that prevents knocking. So the more we can advance the timing the better, up to the point when pressure build-up will be too great before TDC. However, modern combustion chambers can run with less ignition advance with no loss since they have a faster combustion.
Old 12-16-2003, 02:13 AM
I get it...it would never be noticeable, it is more theoretical.
Jon
Old 12-16-2003, 09:10 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Jon
It's at least as noticeable as any power gain due to ignition advance.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 12-16-2003, 12:02 PM
Which, surprisingly, was noticeable for me on my last car. Thanks for the tech...
Old 12-23-2003, 04:21 PM
87montekid 87montekid is offline
Send a message via AIM to 87montekid
Does anyone know what comp ratio is safe to run a 283cid chevy on 87 to 93 octane regular pump gas?
