Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-06-2005, 10:17 AM
billysandra billysandra is offline
Thumbs up Re: Re: Keyless Entry
Originally Posted by Indy8
I can e-mail the instructions to you if you want to post your address. We can't post images here. The DLC is under driver side dashboard. It's tapered on the ends. The wider horizontal row of female pin connectors is where you count from left to right(driver to passenger side), the 4th input and 8th input. The 8th is the last one. Some are color coded, some are numbered(very small). My car has neither, so count to be sure. Ideally, a fused jumper wire should be used to protect the electronics. Most use a SMALL paperclip. I used arts&crafts wire. Just don't damage the pin receptacle.
My email address is [email protected] If you could email me the instructions to program my keyless remote in my 1995 Olds Aurora, I would be grateful.
Thanks,
Billy
Old 12-14-2005, 11:04 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Keyless Entry
The 95 model uses a different remote but the same instructions as the 96-99 models:
GM Remote programming
here's how to do it.
Turn ignition switch "off"
Using a fused jumper, jump data line connector terminal 8 (blk/wht) to terminal 4 Blk close all doors
turn ignition switch "on" door locks cycle
press and hold lock and unlock button on one transmitter alter a 30 second delay the doors will lock and unlock
repeat step to program extra transmitters
do not turn off ignition, if switch is turned off the first transmitter will become inoperative.
disconnect jumper from DLC
NOTES: You do not turn the engine on during programming, only the ignition on. (dash lights and buzzers are on).
The DLC is located below the driver's side dashboard, near the pedals. It will look like a plastic port you connect a computer printer to - about 1" tall by 3" wide.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 12-15-2005, 10:56 AM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Keyless Entry
The instructions I e-mailed were printed by keylessride.com but are thr same.
Quality isn't expensive, it's priceless.
