Old 11-06-2003, 05:13 PM
Sidewinder-03's Avatar
Sidewinder-03 Sidewinder-03 is offline
Re: Re: '69 Camaro RS/SS convert.
Originally Posted by 86_SR5
how'd you do that?
Careful work with a Dremel on low speed with a grinding bit, small flat file, sharp X-Acto blade, and a toothpick(had steak for supper...hehe).
Current projects:
Caballo Diablo ('05 inspired '66 Mustang)
Extreme Firebird (on hold)
Major setback!!!
Paint screwed, body stripped, now have to redo the bodywork.
Old 11-06-2003, 05:19 PM
86_SR5's Avatar
86_SR5 86_SR5 is offline
Re: Re: Re: '69 Camaro RS/SS convert.
I did that, kinda on my lamborghini diablo, when opening up the wheel vents, but I got one side perfect and fudged the other side up, btw, I used a cutting blade, circle thing.
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 11-07-2003, 08:05 PM
The trick is to remove material from behind until you either open up the vents or grill or until you can you can easily cut through it with a knife.
Current projects:
Major setback!!!
Old 11-07-2003, 08:25 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
thats the shizznit! what color is it?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 11-16-2003, 06:29 PM
Not much more done yet, but here's a couple pics of the frame...
Current projects:
Major setback!!!
Old 11-18-2003, 06:30 PM
More progress.
Engine is assembled and mounted onto the frame. Kit distributor is drilled out and wired up to the correct fireing order(the stray wire goes to the coil).
Here's a pic...
Current projects:
Major setback!!!
Old 11-18-2003, 07:05 PM
86_SR5's Avatar
You sure this isn't color changing paint? Sure looks like the body is green and purple in some places.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 11-18-2003, 07:29 PM
No, I have 2 different light sources at my workbench. Incandescent and flourescent.
Current projects:
Major setback!!!
Old 11-19-2003, 02:45 AM
Great work so far!
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 11-19-2003, 02:45 PM
primera man's Avatar
"P-Man"
Excellant work so far...like the idea you done with thr grill
View All My Models Here.
1967 Camaro RS SS 396 4 SPEED PACE REPLICA sappy787 Camaro Discussions 0 09-15-2009 06:57 PM
Ford Mustang 5.0 NOS Vs. Chevy Camaro RS-SS crrrazy Car Videos 2 06-12-2005 01:31 PM
Finished: 1969 Camaro RS/SS Convertible Eric Cole WIP - Street 37 11-19-2004 08:46 AM
92 camaro RS catalytic converter smoking jmy667 Camaro Discussions 22 06-07-2004 06:20 AM
1968 camaro rs ss 396 racing4thesun Camaro Discussions 3 09-12-2002 08:50 PM
