Old 12-14-2001, 12:18 PM
Phatwhippin_CRX Phatwhippin_CRX is offline
Send a message via ICQ to Phatwhippin_CRX Send a message via AIM to Phatwhippin_CRX Send a message via Yahoo to Phatwhippin_CRX
Originally posted by VTEC_boi
http://www.automotiveforums.com/vbulletin/t13199.html
^^Read up my friend
Anyways, I think a header is very much worth it. Just as long as you don't plan on going turbo.
peace
boi
Like Dez said, it's a blanket statement that does NOT apply to all cars...
ESPECIALLY small displacement, no torque Hondas that need to rev HIGH to make any power. Our small economy cars NEED backpressure to produce any kind of low end torque.......... which is what makes cars move, HP is what makes them fast.......
1989 DOHC VTEC CRX Si
C'mon, it's only a Honduh...can't be fast!
I AM the Anti-Rice!
Swap info, Turbo tech, and naked chicks!
Old 12-14-2001, 12:20 PM
Originally posted by madtownhonda
yep, that thread explains the entire thing..thanks for posting that link
Un-bolt your exhaust at the header and drive around for a week like that, then tell me where your low-end power goes. Trust me, I drove around like that for a week and the car couldnt move out of its own damn way until 4800 rpms when it just pulled like a bat out of hell.
For a full out drag car, backpressure = bad
Daily driven? you need it.....
I AM the Anti-Rice!
Old 12-14-2001, 10:36 PM
Ktulu Ktulu is offline
That just doesn't go for 4 bangers. I frequently check out the windsor (5.0L and 5.8L found in mustangs) forum at corral.net and they also say you need backpressure. There are some really intellegent people there that could explain to you why you need it.
Anyway,
Ktulu
Old 12-15-2001, 06:14 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
backpressure on any car is bad no matter what the condition period.
Q. do you know why you loose low end power when you remove your exhaust at the header?
A. an exhaust system doesnt exist soley to provide sex appeal my friends and nor does it exist to provide backpressure. what it does exist for is its scavanging capabilities. at a low rpm the cat back section is necessary for keeping the egts up and creating a path for exhaust to travel so the velocity remains high and it can scavange the exhaust behind it and pull it forward towards the muffler where at that point it will be expelled. the cat back is in essence a suction pump for exhaust gas in the lower rpm range because it doesnt have the velocity on its own to move freely out of the system. take the header off at low rpm and you are actually creating backpressure from the turbulance of not having a controlled flow or not having any suction to pull recently expelled gases out of the header. all this leads to reversion which is why you have shit for power if you take it off at the header.
you need the catback not to create backpressure, you need it to help scavange your header in the low rpm range. after a given point in the rpm scale a catback or any exhaust becomes a restriction because the rapidly increasing rpm which means rapidly increasing flow volume of exhaust gas has enough velocity of its own to push gas out of the header. a perfect system would have the whole exhaust on untill a switchover point where it would switch to an open header. unfortunatly noise and emissions laws and general stupidity prvent that from happening.
if ya dont believe it then i can let you talk to some mechanical engineers that are friends of mine and they can get way more technical to clarify anything for you.
Old 12-16-2001, 04:09 PM
VTEC_boi's Avatar
VTEC_boi VTEC_boi is offline
Send a message via AIM to VTEC_boi
thanks for the backup Rick hehehe
"Son, your eyes look a little red there. You've been hittin the Vtec haven't you? Alright, stand on one foot, touch your nose and say 'Third Rocker Arm'".
Original PH Member (Reppin' for original PH'ers!)
www.lunspeed.com
www.jdmcivic.com
www.sweetcarz.com
Old 12-27-2001, 04:19 AM
Si2000 Vtec Si2000 Vtec is offline
Send a message via AIM to Si2000 Vtec
Apparently the new JG Header pumps out 13 hp to a B18C1??? I guess Import Tuner dyno'd it at that much. That's a lot of power, the draw-back is it cost around $600. I think if I get a header, I'll get a 2.5" collector'd Type-R Header... Better dyno results than DC, and its HONDA OEM.
Old 12-29-2001, 05:47 AM
sindogg sindogg is offline
if not planning on going turbo get the header.
Old 12-30-2001, 08:25 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
Bla bla, the point is dynos show they don't do shit on civics , you can get as technical as you want, including moisture levels in the atmosphere, tempereature, atmoization of fuel in the combustion process. But is still does not take away the fact on a stock motor, especially the SOHC civics lose power using 4-1 headers on 70% of the rev band and 4-2-1s produce minor gains, when combined with an exaust you'd be lucky to get 6 HP at the wheels and that is not noticable.
M.Sanew - AutomotiveArticles.com
Old 12-30-2001, 10:56 AM
ric's Avatar
ric ric is offline
agreed on for a civic (unless its supercharged). but larger motors can greatly benefit from them.
Old 12-30-2001, 11:24 AM
delsolguy's Avatar
delsolguy delsolguy is offline
Send a message via AIM to delsolguy
http://www.automotiveperformanceengi...om/header.html
Might wanna compare the graphs....
1997 del Sol VTEC
Basic Mods completed. Dreaming of a set of cams...
