Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-09-2003, 06:59 AM
95blackGS-R 95blackGS-R is offline
All b16, b18,b20 will all fit in the civic.
Old 10-09-2003, 02:51 PM
Mellason Mellason is offline
I'm not a honda guy but the integra out classes the civic. I'm talking jdm specs. There is a japanese site showing a drag race between Tpye-r civic and the type-r integra. the integra smoked the civic by far from start to finish. When I find the site I'll reply. If you drag a civic sir vs an integra gs of corse the civic will win, but class it with an integra sir jdm or gsr U.S the civic don't have a chance
Old 10-09-2003, 05:10 PM
D[X]P's Avatar
D[X]P D[X]P is offline
Send a message via ICQ to D[X]P Send a message via AIM to D[X]P
ok thx guys
Failure is only the opportunity to begin again more intelligently.
Old 10-10-2003, 02:09 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
Re: Clvic Vs Integra
Originally Posted by 95blackGS-R
I think that if you are going to stay with a stock car then the integra is way better. More potienal, more torgue. Civic are lighter that is the 92-95 dx model with no power anything. The integra GS-R comes with 1.8 dohc vtec 170 hp. The civic don't come with dohc vtec.
the 99-up si came with DOHC VTEC motors.
first the b16a in the 6th gen, then the k20a2 in the 7th gen.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 10-10-2003, 05:43 PM
EliteConcepts's Avatar
EliteConcepts EliteConcepts is offline
Banned
Send a message via AIM to EliteConcepts Send a message via Yahoo to EliteConcepts
Does any one know what Jotech is..?. Or Kenny Tran.. All this talk about how Integra's are better and more potental is wrong. there both honda engine the main thing that seperates these enigins apart is the gear ratio.. thats it thats why the b18 integra can beat the b18 civic.. Its all in the ratio. they have basically the same amount of mods available. Oh Yeah and the Soc d16 vtec has more potential then any other honda motor other then the k series motors witch are what is in the S2000.. Kenny Tran has a 8.5 second civic. still using the soc 1.6 liter vtec motor that comes stock.. you can visit there website and see his car and my car in the pics section I have the yellow Integra with the H22 swap.. you want a nice engine pick yourself up one of those.. very nice..
My mods are on www.jotech.com
Integra
11.3@128mph.
thanks to my awsome engineers and Greddy E-man Systems...
Old 10-11-2003, 08:57 PM
Integra
11.3@128mph.
wha?
1st off, kenny tran is not running a 1.6 liter motor, simple as that.
the SOHC VTEC motor that u are speaking about doesn't have nearly the amount of potential that the DOHC motors do. please explain how a single cam motor with less displacement (which is huge in straight line racing) has more potential than its big brother?
next...when u swap in a b18c1/5 or b18b1 motor from an integra, u swap in the transmission as well, therefore, u have the same gear ratios.
a 94 civic dx with a b18c1 swap vs a gsr would have the b18c1 swapped civic beating the gsr stock vs stock.
next...the k series motor is found in the rsx (base is k20a2, type-s is k20a3) an also the 7th gen civic si (k20a2) NOT the S2K.
next...the S2K actually rolls the highly regarded F20 motor.
last: the integras an civics that u are speaking about (the ones on NHRA) are hardly even civics or integras any longer.
it's basically jus a mold of the old frame.
ok, i lied, LAST: the integra stock vs stock with the civic (which is the only way to fairly argue this issue) has the integra out-classing any civic made yet.
read my other post.
name one civic that is on the level of the integra type r.
please actually do some research and know what u are talking about before posting.
one last thing...in my opinion, the k20a3 has MUCH more potential than any other motor so far released. name one other honda motor that can push 240+ to the wheels with i/h/e/cams/ecu.
2003 Infiniti G35
Old 10-12-2003, 09:12 AM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
Integra
11.3@128mph.
i don't know any stock civic with a b18, unless it is swapped. if ur reffering to the new ones they have a 1.7l engine but thier hp is still the same as the 1.6l, only thing that change was the displacement (this was what the guys at the honda forum told me). two guys on streets w the 1.7 civics wanted to race me, they both had exhaust (even more bolt ons i bet, but didn't look under the hood) an wanted to go against my integ, but i spanked both of them.
another thing, sohc d16 vtec= 127 hp and 107 tq, and u say this has potential? i would choose any b series motor anyday. why do u think all the civic guys are doing engine swaps w/ integ motors.
Old 10-12-2003, 09:52 AM
tran_nsx's Avatar
Re: Re: Clvic Vs Integra
u should correct this statement, the k20a3 makes 200 hp at the crank so about 170-180 at the wheels. i don't see anyway i/h/e/cams/ecu will get 60+ hp to the wheels.
Old 10-15-2003, 03:26 AM
Re: Re: Re: Clvic Vs Integra
u don't believe it?
the toda cams, (tested in import tuner) valve springs and ecu showed a jump from 171 hp to 220 hp.
i/h/e will give a k20a3 atleast 20 hp (proven MANY times on dyno's)
so there is ur 60 hp right there.
i/e/hondata gave my frien the power to run a 14.3 alone (down from a 15.2 stock time)
no, so u have no say in that matter. i stand behind it 100%. name another motor that will show better gains that was made by honda.
2003 Infiniti G35
Old 10-15-2003, 04:58 AM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Never argue with KrNxRaCer00. He is always right and will back everything up.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 10-15-2003, 11:24 PM
tran_nsx's Avatar
Re: Re: Re: Re: Clvic Vs Integra
u don't believe it?
no i don't believe it, but this doesn't mean it's not possible. how about u give me a link to the article that has this info instead of giving me a more detail hearsay. oh and by the way, weren't you the one that stated not to be a mag racer, ironic isn't it?
Old 10-15-2003, 11:35 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
thems fightin wurds...
Old 10-16-2003, 12:29 AM
tran_nsx's Avatar
hey sameintheendo1 i don't know about u, but when i see some pretty wild claims no matter if its coming from a bum off the street or a university professor, im always going to ask why. don't get offended by this since it wasn't meant to be offensive in the first place. now thier might be some gullible people out there, but im not one of them.
for example, just ten years ago drag racer's claim an import hitting 9's would be impossibe to accomplish especially by the domestic crowd, as u can see this isn't true. another example would be from my personal experience, i went to this body/racing shop to observe how well their craftsmanship is held. one thing i've discovered was that they were more affordable they a lot of other shops, so thats was a plus. what killed it was their claim of power a crx they have which has been swapped with a b20 motor with turbo. they claimed the b20 not including the turbo (from a crv, for people who don't know) pumps out 220 hp stock! i ask them how the hell they come up with that conclusion? again stated another wild claim not to mention it sounded to be a biased opinion. they said the b20 is one of the most powerful motors.
so instead of debating with them since its already going to be talking to a brick wall, i just left it alone and said whatever. now i know the b20 does not push out 220hp, if u think about it thats more than the type-r or type-s. they claim the b20 is in the same territory power range as the rsx type-r and jdm prelude sir. i also know its not one of the most powerful motors out there, although it would be an awesome base to start off for force induction just like the b181a/b. now i know why their prices aren't as high as the competition.
this was kinda long so i want to apologize ahead of time. there are several similar points in all of this, one can be--if it sounds too good to be true, it proabably is. another--don't believe in everything u hear, and--if your gonna make a claim have the resources to back it up. the main point however would frankly be, don't be gullible people.
Old 10-16-2003, 12:53 AM
Re: Re: Re: Re: Re: Clvic Vs Integra
1st, i've seen ppl dyno their rsx's (give me a few days an i'll try to get a dyno sheet from them), i was giving u an example SINCE u seem to love the magazine stats so much.
2nd, if u want to bring up that old arguement, PM me an we'll save ppl's bandwidth.
last, u can't argue with 14.3 from those modifications, its as plain as simple as that. i do agree the b20 is a great motor (as is the b18a/b), but those take FI to put down the numbers that the k20a3 will with simple mods.
here's the link to the article: http://importtuner.com/tech/0308it_rsxcams/
u've gotta give me time to meet up w/ those ppl (they're at college), but i'll get the other dyno's as well.
2003 Infiniti G35
Old 10-16-2003, 03:21 AM
tran_nsx's Avatar
u should read the article again. im not trying to degrade and make u look bad just want to make sure what your stating is true.
95 Integra LS with B18 A1 VSS location? cwshifflett Integra 1 02-05-2011 08:32 PM
95 Integra with VSS problems + more...need help! cwshifflett Integra 0 10-27-2010 03:42 PM
90 Integra GS: Problems Galore crazzzyace08 How-To's and Walk-Through's 1 12-22-2009 05:21 PM
94 Acura Integra HELM manual like new skola239 Classifieds 0 03-22-2009 09:56 AM
