Go Back   Automotive Forums Car Chat > Racing > Technical
Technical Discuss different strategies and theories of the racing aspect.
Old 11-22-2004, 11:38 PM
tricksaturnsc2 tricksaturnsc2 is offline
Re: what is torque?
Torque is good for burnouts, hp is good for selling cars & winning races.
Old 11-26-2004, 10:04 PM
Zgringo Zgringo is offline
Torque is when your standing in front of the john and need to point your tool down, so you don't miss. In pushing it down it raises both feet off the ground, Thats torque. Jk
Some good answers.
Old 12-30-2004, 02:42 PM
hemip's Avatar
hemip hemip is offline
Re: lb-ft
Originally Posted by jhillyer
One way I think of horsepower is as torque-rpm with engines that tap power through torque. Ignoring other parts and effects, the engine's crank height determines torque derived from that power. But I might we way off -- if so, don't tell me, because I don't want to be disturbed about this topic. Bliss...
I also like to think of horsepower or Watts straight from a rocket nozzle. It's energy derived from fuel. Fuel into power. But, that is straight torque too. Torque becomes more relevant when using leverage. The rocket might blast the same rate all its life, but if we vary the nozzle or give it a working surface to push against, it's torque increases. Similarly, we can place the rocket on a lever or gear to vary it's torque higher or lower. Stating this, I'm trying to avoid discussion of Moment.
Does torque exist without motion? Can one have static torque? Static power?
Reading the other replies, I agree.
-edit-
Oh yeah, and why converting more fuel to the rocket increases power, and why higher RPM increase power, and why power is linear with RPM, ignoring inefficiencies.
Good thinking!
Many peaople thinks TQ happen at low rpm and Hp at high rpm.
Or , that Tq is a low rpm phanomenon. When in fact high rpm motors produce the best Tq numbers.
Allright, the car weights 3000p. The motor has a Tq of 500 fp. How fast will it do the quatermile?
I just said this with the static Tq in mind.
Goran Malmberg
Old 12-30-2004, 03:23 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: what is torque?
FYI Pounds are expressed lb not P. P is pressure. anyways.
Im glad some people where smart enough to Explain why Torque isnt everything.
Torque- Defined in ft/lbs or lb/ft either eay it translates into the same amount of rotational force.
An engine's defined what work can be done. there is no alot ed ammount of time. Sure i have 500 lb/ft of torque but its at 500 RPM and im never going to get moving. (oh and torque can also be defined in Newton/meters or Kg/M. in reality it should be defined always as Newton's because a newton is a measuremnt of force, lb is a measurement of gravity pull and Kg is 1000grams, ie Mass or how much of a material is there. torque if force and there for SHOULD be defined as Newtons. but since we are living on earth with 1G Mass has weight and weight exerts force so....)
RPM- plain and simple is rotation per minute.
Horse Power: this is a hard one. THIS IS WHAT MATTERS WHEN THINKING OF ALL OUT PERFORMANCE, NOT EVERDAY DRIVEABILITY. the true formula is 33,000 lb/feet per min. but since you cant expect a horse to lift 33,000lbs 1ft or expect it to move 1lb 33,000 feet in one minute its more simply defined as Torque(RPM/5252). but that has already been said.
1HP=746w (i beleive)
1w=joule/sec.
A joule is a measurement of all out energy. what does this mean? Well alot of muscle car guys like to say its torque that gets you off the line. True, in a sence. its torque to the wheels that gets you off the line. so we have a good old american muscel V8 cranking out a flabergasting 500 ft/lbs of torque at a mere 2,000RPM. thats 190hp@2000RPM. now we have out European performance i-6 with 333hp@7,000 RPM. thats 250lb/ft@7000RPM. Which should launch faster? well lets assume in first gear the muscel car has a final drive of 16:1. 500*16=8,000 lb/ft of torque at 125 RPM. the euro sport car makes most of its power in the high high RPMS so it has a very short 1st gear. 32:1 8,000 lb/ft@218RPM this means that the euro sport car will take off faster because it has more torque at a higher RPM and therefor more HP. you se its all about gear ratio's. torque can be multiplied through gear ratio's HP is constant no matter what gear ratio you put it through.
so what does all this mean? well not only with the euro take off faster but because it has more over all energy it can go faster because in the end it takes HP (Kw) to brake through the air at high speeds, not just torque.
But let me ask you this. Which will be more comfertable for everyday driving? well the engine with 500lb/ft &2000RPM. why? well with that short of a 1st gear slow driving will waste gas and nobody wants to wind their engine up to 7000RPM everytime they need to pass somebody.
for the best all around engine an engine that makes decent torque in the lower RPM's but can hold a flat enough torque curve to make good power in the upper RPM's is perfect. if you are looking for good gas milage and a quite ride then lots of low end torque is your alley. if all you want to do is treat the road like your race trak then lots of HP is ideal.
And here is an idea to throw out at the muscle car people before they flame me for saying some euro POS will beat their cars off the line. 90% OF YOUR CARS WENT DESIGNED FOR STRAIGHTLINE PERFORMANCE. THEY ARE FULL SIZED SEDANS WITH TOO MUCH POWER FOR THEIR CHASIS MENT FOR GREAT EVERYDAY, LOW RPM DRIVING.
i love muscle cars such as the 426 Hemi, GTO, Stingray, GT500Kr, but all of these old family sedans (Bel Air's especially annoy me. they belong shoped and bagged, not raised in the rear and doing wheelies at the local 1/4 mile) built up to 400 lb/ft of torque and 350HP are stupid IMO.
Old 12-30-2004, 04:22 PM
hemip's Avatar
Talking Re: Re: what is torque?
Flymann, absolutley right so.
Then we might have a lever arm with a weight at the end hanging on it all day loong, creating Tq with no Hp. We may create ANY number of TQ with handcraft, say 10000fp, by using a lever loong enough. But it want give a 3000p car very much of a speed. Just one Hp or so.
But if we have 500 Hp we can tell a quatermile time for the 3000p heavy car, right. Tq is of no concern then, it should be as fast with any number.
It is the same phenomenon if the car accelerate at 1500 rpm at 25mph or 100 mph and 6000 rpm. Hp tells how fast the work is done in both examples.
Are you making speakers? Great I have been makint 1000ands of them!
You also like HEMIS:s? Even greater. I drive one myself.
Goran Malmberg
Old 12-30-2004, 09:22 PM
dampachi's Avatar
dampachi dampachi is offline
Banned
Send a message via AIM to dampachi Send a message via MSN to dampachi Send a message via Yahoo to dampachi
Re: what is torque?
tricksaturn...the saying is actually 'horsepower sells cars, torque wins races"
Old 12-31-2004, 01:41 AM
Alastor187 Alastor187 is offline
Since torque is force times distances the units are more accurately written as lb-ft or ft-lb.
|_|_|_|_|_|_|_|_|_|
Old 01-02-2005, 12:17 AM
Andy Dorsett Andy Dorsett is offline
If you are an engineer lb-ft is torque and ft-lb is energy. You will hear us say them incorrectly often out of bad habit just like you will hear us talk about how much power our motor has when a motor is an electromechanical device and what we really mean to say is engine. Let me go ahead and get the General Motors and Ford Motor Compant out of the way. I knew that is what you where thinking of saying.
Old 01-02-2005, 01:42 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
To add a bit to this, i'd like to mention the unimportance of a high peak torque, if it peaks too soon (also of course if horsepower doesn't pick up soon after torque starts to drop off). This is not to say that having a lot of torque is a bad thing. But people must understand that when you look at a dyno graph, what you want is a flat torque curve. It's the amount of area beneath the curve that counts, not how high the curve goes.
Old 01-04-2005, 08:57 PM
buymeabmwm3 buymeabmwm3 is offline
Re: what is torque?
Torque is also a terrible, terrible movie.
1992 BMW 325i conv.
FOR SALE!!
IM me for more info. $6300 /obo
2005 Ducati Monster 620 i.e.
2005 Toyota Tacoma V6 4x4 Double Cab, TRD Off-Road - FINALLY HERE!
Horsepower is 100 ewoks poking you with pointy sticks.
Torque is one wookie pulling your arms out of their sockets.
