Old 11-30-2004, 02:27 PM
Bunboys's Avatar
Bunboys Bunboys is offline
Re: Differential problems on 00' Silverado
Originally Posted by hayesbcajh
So, how hard is it to replace just the diff and not the whole rear end? Most people say just replace the whole thing. The haynes manual says don't even bother touching it.
I found it pretty easy to do the swap, I used the same Ring and Pinion so I only had to worry about the carrier shims and not the pinions. I have some pretty good instructions I found from research I did prior to doing the job, I can send you a copy if you want. The only word of caution would be make sure to have plenty of shims on hand, preferebly not the cast ones like the stock ones because they seem to be a little brittle and break.
Old 11-30-2004, 02:37 PM
hayesbcajh hayesbcajh is offline
Re: Re: Differential problems on 00' Silverado
That would be great if you could send the instructions. Thank you.
Old 11-30-2004, 08:31 PM
skipr skipr is offline
You are still gonna need a dial indicator, and if you plan on a ring gear replacement, you just opened up a whole other can of worms. because you hav to change pinions with rings, they are all matched sets. Pressing out the old bearings and races is a huge pain in the ass. And pressing in the new races is even bigger pain in the ass (referring to pinion gear bearings). At the very least you will need to know your backlash and contact pattern which requires a dial indicator w/magnetic base.
Old 11-30-2004, 11:48 PM
Bunboys's Avatar
Very true but I dont believe that he is replacing the ring and pinion, only the posi unit. the bearings will have to be pressed on to the new unit and the races bolt in. he will have to preload the bearings to aquire a true read from the contact pattern. All of this is included in the detailed instructions Im sending him, it also covers ring and pinion replacement. As for anyone reading this post, skipr is 100% correct with what he says. This can very easily turn into a BIG pain in the ass! I wouldnt recomend anyone attempting to do this unless they have mechanical experience, the proper tools, and can follow directions.
p.s. and a friend with a car to take you around for parts
Old 12-01-2004, 12:06 PM
It seems you have gone through this headache yourself.
Old 12-02-2004, 04:10 PM
rrousou rrousou is offline
GM units junk..Get an Auburn Gear. I put in several and with some mechanical knowledge you can do it in about 3 hours. No shiming required.
Old 12-02-2004, 04:48 PM
Are you saying that your backlash comes out perfect on first atempt? Or you don't bother checking? Close is good enough huh?
Old 12-03-2004, 02:38 AM
Bunboys's Avatar
Re: Re: Re: Differential problems on 00' Silverado
No Shims??? Can you please explain?
Old 03-09-2005, 08:13 PM
intel_guy intel_guy is offline
would this kit work on a G80 differential ? I asked the guy selling and got no response. So I figure i'd ask the experts.
thanks.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old 03-10-2005, 12:30 AM
thanks.
Yea it will work, but I wouldn't buy Koyo bearings. The OEM replacements are Timken bearings. A good manufactor (USA made) that has been in the buisness for over 50 years.You will pay more, but why go cheap on something like this. Alot of stress riding on those bearings.
Old 03-10-2005, 08:51 AM
99redsilverado's Avatar
99redsilverado 99redsilverado is offline
i would pull the cover, assess the damaga and if there are alot of metal shavings, replace the entire rear end...jasper 3 yr 75k warranty is awesome...i had the same noise, and ended up throwing half of my diff out of the cover, made a whole the size of my fist, email me and i will show you pics [email protected]
Old 03-10-2005, 09:53 AM
Actually, if I open it up, clean it out, replace the cover, put new fluid in, and still have an issue, I'll probably let Cottman do a complete repair for me at a cost of about $300-400. That way it's fully covered if it's not done right. I'd love to experiment, but if I screw up on a big ticket item like this then that's just wasteful. Alternatively, maybe I should get the eaton differential and be done with it...decisions decisions...
I found this link:
http://www.gm-trucks.com/IAR_RearDifffluid.shtml
It does not give any details as to how they are cleaning the differential out. Once you have the cover removed, they say to clean it out. Is there a fluid you can spray in there to flush the parts ? Or are they just cleaning the inside of the cover ?
Old 02-12-2009, 06:23 PM
arkyinaz arkyinaz is offline
I have a 2000 Chevy Silveraldo 1500 4x4 and have to replace the spider gears on my truck, after several phone calls I found where I need to purchase them, the owner has had three phone calls today on these gears alone, after reading this forum and going through my own dilemma, I was wanting to email Chevy to find out why something hasn't been done by them to resolve this problem. This should be a recall. I visited the Chevy website and nowhere in there was a link that I could talk to them directly, there is however an address. I will send them a letter, what I'm wondering is, has anyone complained to Chevy about this problem? I am a diehard Chevy fan but this truck has just about changed my mind. I have had more problems and have spent more money on this one truck then I really care to talk about. Have you guys said anything to Chevy??
Old 02-12-2009, 06:32 PM
j cAT j cAT is offline
this posting is too old,,,,,,, start new post of your own....
