Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 11-30-2001, 02:50 PM
gdalton's Avatar
gdalton gdalton is offline
You rock man thanks.
05 Big Blue Stepside
“Somebody kicked my dog Mavis and I’m going to find out just who the hell it was. I’m all messed up on cough syrup right now so just like nevermind.”
Old 11-30-2001, 02:56 PM
APEXSER APEXSER is offline
Re: Re: Write Up!
Originally posted by G-Forces
Sure thing I'll give you a URL of the initial draft and we can go from there.
Just let me know!
Louis
Old 11-30-2001, 03:26 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
Re: How to choose the right turbo!
Originally posted by APEXSER
3. Hotshot Turbo Kit
This setup comes with a Stainless steel manifold <snip> It spools up somewhere in the 2500 rpm range and should create full boost in the 3000-3200 rpm range! The T3 turbo is capable of producing 300 whp!
See this where I kind of wanted to go. 300 easy wheel hp with the turbo mounted under the manifold but I wanted a turbo that could handle 300 hp at the wheels at about 80% of the turbo capacity. Would this still be a good setup? What percentage of its performance potential would this turbo be running at 300whp?
Old 11-30-2001, 03:38 PM
Re: Re: How to choose the right turbo!
You can get the T3 with the .63 A/R Housing w/ Stage III Turbine and Super 60 compressor housing & wheel and it *should* be able to support pretty close to 300 hp. You are looking right around ~280-285 realistically! If you go with the .82 A/R housing, it will be a little laggier, but it will insure that you hit 300 hp. The .63 housing is ideal for the street! It would be a great turbo. You can also get the exhaust housing Extrude Honed to help spool! At 10 psi, you should be able to make 225-240 hp. You will need the Cobra MAF though and 50 lb/hr injectors. Let me know when you are interested in getting the kit! I can try and eithe rpiece one together for less or get you the best price on the kit. I don't particularly care for the Bosch BOV and HKS Front mont intercooler that the kit comes with! I can possibley get you a better price on a different intercooler. Have you considered the GTiR setup on your car? The T28 along with some 50 lb/hr injectors, Cobra MAF, Walbro Pump, and Larg intercooler will be *NASTY* on the street!
Louis Anaya
1992 Nissan Sentra SE-R Turbo
12.0 @ 118.77 mph
349.6 HP & 301.9 FT/LB
SR20 Performance
www.sr20performance.com
480-966-SR20
480-966-0100 Fax
Old 11-30-2001, 05:28 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
well done
1.6 - The Underdog
GA16DE-T Club!
Old 11-30-2001, 07:02 PM
G-Forces's Avatar
Banned
Re: Re: Re: How to choose the right turbo!
Thanks. I'm considering a LOT of things right now. GTi-R is one of them. Just doing the basic swap for now and that should hold me for a bit then getting the 50lbs, Cobra MAF and bigger intercooler later. Although I'd probably spring for a decent FMIC right off the bat with the GTi-R motor. I know it's more but...it's damn sweet!
Old 12-01-2001, 08:52 PM
P10DET's Avatar
P10DET P10DET is offline
Originally posted by lloyd_nickens
please do. It is very helpful information for those of us who would like to get into that type of stuff
Try finding the December issue of Sport Compact Car.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 12-01-2001, 08:56 PM
P10DET's Avatar
Originally posted by gdalton
What about the ecu, I know for max performance you would have to get one reprogramed or an new one all together but can you use the turbo with a stock ecu
Let's see.... How can I put this properly?........
NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO
George Roffe
Houston, Texas USA
00 328i
Old 12-01-2001, 09:12 PM
P10DET's Avatar
Re: Road Racing
I am no expert on Road Racing , that is for sure, but I do know from what *I* have seen at tracks like Button Willow, a high hp vehicle with an FMAX kit would have too much power. I know that was the case with Mike Mager a couple of years ago. The power would kick in so harsh he ended up breaking his tranny.
While I wouldn't exactly call myself an expert, road racing is my arena and I think the problem is not so much the power, but how it's used. You can't just mash the throttle on a road course, you have to feed it in as the tires have traction available.
That said, I don't think the chassis are able to handle that much power very well other than in a straight line, so in a way I'm agreeing with you, but not totally.
I think the T25 would be a *great* road course turbo! Great for the straights, great for quick acceleration or passing, and quick spool out of the turns. A T25 will have very good mid range power! The T25 will more than likely not make more than 220 hp, so you won't have this surge of power out of teh corners. *I* think it would be great! The T25 is very predictable in the power band! I have a hard time imagining a T25 breaking some Road Race tires loose, especially when they are warmed up!
I think the T28 or T3 would be a little better. Basically, you don't want to run out of breath at high rpm like the T25 does. Other than that, keeping lag to an absolute minimum is very important. You want to know when the power is coming on, else you can end up losing traction and possibly spinning or worse.
George Roffe
Houston, Texas USA
00 328i
Old 12-01-2001, 09:19 PM
P10DET's Avatar
Jason, you want the turbo that Rob Cadle spec'd for Ray Kawski. It's based upon a T28, but much better. Totally kick ass. It uses a GTi-R manifold.
George Roffe
Houston, Texas USA
00 328i
Old 12-01-2001, 09:47 PM
The only thing different is the Compressor housing! Rob Cadle likes to use the T04B compressor housing from the S14 turbo and put it on the GTiR turbo! That is it!
Louis Anaya
12.0 @ 118.77 mph
SR20 Performance
480-966-SR20
480-966-0100 Fax
Old 12-01-2001, 11:08 PM
G-Forces's Avatar
Banned
Re: Re: Re: Re: How to choose the right turbo!
As long as it fits under the manifold I'm cool with it. I don't like the configuration of the F-max kit. To obvious if you know what I mean.
Old 12-01-2001, 11:11 PM
G-Forces's Avatar
Banned
I don't know the specifics of Ray's turbo but I know I'd like the turbo that was spec'd for the B15 turbo that Mike helped build. It might be the same one but 300whp is about all I'm looking at.
At this point I'm thinking of a straight GTi-R swap (I know, I know) then adding the injectors, fuel rail, MAF, tuning in a second stage for about 300whp.
But plans change like the wind so this might change in a couple weeks.
Old 12-02-2001, 07:41 PM
2002G20Racer's Avatar
2002G20Racer 2002G20Racer is offline
Does the Blue Bird setup work on 2000+ G20s? The reason I ask this is because of the differences in 99 and lower SR20DEs's and the newer SR20DE's.
Anyone who tells you money is the root of all evil, doesnt f#!@ing have any.
Old 12-02-2001, 08:01 PM
G-Forces's Avatar
Banned
It would fit fine. Working out the ECU problem is probably the biggest hurdle.
How to choose the right bmw car for you tito4444 6 Series 3 10-10-2010 02:11 AM
help choosing the right intake 95-GST Off-Topic 0 11-12-2004 11:34 AM
how do you find the right turbo. raven_240 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 05-08-2004 02:17 AM
Choosing The Right Vehicle For Your Family: Minivans Bruce Levinson Engineering/ Technical 0 12-01-2003 03:56 PM
TIRES--Help Me Choose the Right Set Please fordlife Mustang Talk 5 03-05-2003 10:03 PM
