Old 09-25-2003, 04:48 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
you dont have to remove the wheel well.
The heater core is in the black box between the dash and the firewall.
If you look in the engine compartment where the heater hoses attach to the core, that will give you a good reference where it is.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-25-2003, 08:05 PM
tingham tingham is offline
Send a message via ICQ to tingham
heater core removal
Shawn,
You don't have to remove the passenger side fender. You do have to have pretty good clearance behind the dash on the passenger side. Once you get in where you can "function" behind the dash, you'll see a black plastic housing unit. It sits directly below the glove box. It has about 6 bolts around the edges of the housing. Once you get that opened up, you have a bracket around each end of the heater core. That has 4 more screws to remove. After that you should be able to just lift the core out. CAREFULLY cuz if it's leaking badly, it'll drip everywhere! Suggest that you use a clean cloth to wipe down as much of the housing and vent system as you can.
If you can't get behind the dash well enough to pull that housing, you may have to pull the parking brake handle off so that you can pull the dash out further. The brake handle is attached to a lever with a spring and hook attachment. You have to pull the lever towards the handle and disconnect the hook. We actually had to take our dash completely out to have enough room to work. Needless to say, that's why the "shop" wants $300-$400 to replace that $20 part! Good Luck! Hope this helps!
Twila
Old 09-25-2003, 08:34 PM
shawnbiel shawnbiel is offline
Thumbs up Re: Re: 1994 Chevy S10 Blazer
ok i see the black box. can i get to it just from outside or do i need to get from inside also???? an air conditioning tube is going into the box as well.
Old 09-25-2003, 08:53 PM
Smile Re: Re: Re: 1994 Chevy S10 Blazer
ok ill try it. thanks.
Old 12-26-2003, 04:53 PM
NAD42 NAD42 is offline
I need help too...I'm 2 1/2 hours into the project and have the dash apart and just lowered the steering column...the dash doesn't seem to be getting any looser,,,I have to go get a small torx to remove speaker covers and hopefully after I get the screws out underneath the covers thatll loosen things up some more...Ive only cursed 3 or 4 times so far...not bad for me on stuff like this.
Old 12-27-2003, 09:28 PM
tom3 tom3 is offline
Read this article first. A couple shortcuts and they work, I've followed this procedure a couple times.
http://www.sytyarchives.com/howto/vi...imate_controls
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 09:35 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
1994 chevy s10 blazer codes 83 ATC mechanic Problem Diagnosis 0 06-27-2008 02:44 PM
1994 chevy s10 blazer 4.3l cpi runnin like crap myers47371 Problem Diagnosis 8 12-01-2007 10:41 AM
Ideas on value of 1994 Chevy S10 Blazer 4x4 with 4.3 CPI 93LT Blazer 3 10-25-2005 10:17 PM
