Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 08-20-2003, 12:19 PM
tofstchvy tofstchvy is offline
Send a message via AIM to tofstchvy Send a message via Yahoo to tofstchvy
My car has the hks 2.8 kit and the t-51 spl bb. That run was at 1.8 boost. It is set to run at 2.4 boost. The dyno couldn't handle anything more than that. Unfortunatly my car has been stuck in an importing struggle for the past nine months. It is hard to say if I will ever get the car. (BTW I am trying to do it the legal way.)
http://www.joulespeed.com
Old 08-20-2003, 01:28 PM
omegasky omegasky is offline
Re: How much power do you have?
what you mean like 34psi of boost, that's a lot of boost, mind me askng what mod's you got to back up your boost setting's, that much boost will blow a headgasket off any street car!!
Old 08-20-2003, 02:03 PM
Gtr2.7L Gtr2.7L is offline
386 AWHP at 1.02 Bar.....
est 420 AWHP at 1.2 Bar.....
as you can see, I was heading for an easy 420 on the second run at 1.2 bar, when one of the straps broke....whoops!
I had to settle for a third run of 386. Hell!
Old 11-25-2003, 04:48 AM
Skiier Skiier is offline
Question?
because most of get our cars tested on rolling roads which will give power at the wheels. Everyone likes to talk about power att eh crank.
Does anyone know what the powertrain losses are for a GTR? ie anyone had an engine on a dyno then rolling road too?
Old 11-25-2003, 12:01 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
It has to vary depending on the torque split going to the front.
I have heard its normally around 25%, but that should be with the fronts engaged. 25% for a manual and RWD would be insane.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 11-26-2003, 04:56 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
The average on RWD with the skylines vintage car is about 20%, and AWD car from the same era is bout 30%, so if running on only a RWD dyno, (i.e. fround drive disconected) then 20% would be a nice conservative power loss figure to go with, but you probobly want to allow maybe 2-3% each way as margin for error.
Old 05-14-2004, 12:31 AM
tazdev's Avatar
tazdev tazdev is offline
I'm still here
Haven't scanned the graph yet.
168KW from my 25T with stock boost and slipping clutch (razor can verify )
Old 05-14-2004, 12:35 AM
SkylineUSA's Avatar
tazdev,
Do you know the conversion from KW to HP. For some reason, I always forget that one. I am thinking its like 1.2:1, but I could be way off. I have a lot of numbers running around in my head
Old 05-17-2004, 04:21 AM
tazdev's Avatar
I'm still here
kw - hp x 1.34 hp - kw x 0.746
ps - hp x 0.986 hp - ps x 1.01
ps - kw x 0.735 kw - ps x 1.36
any other numbers you require
so my T has 225hp
Old 05-17-2004, 12:53 PM
SkylineUSA's Avatar
tazdev,
Kewl, thanks man!
Old 06-19-2004, 09:00 PM
InfestedShadow InfestedShadow is offline
Send a message via MSN to InfestedShadow Send a message via Yahoo to InfestedShadow
I went on motorex.net site and my father told me the specs aren't that good...
0-100 mph 13 secs, a suzuki esteem is faster than that...I don't understand...plz someone explain me
Old 06-20-2004, 12:46 AM
SkylineUSA's Avatar
Ferrari specs aren't that good either, but poeple buy them.
And your father drives a?
Its not a cars ability to go from 0-60, or 0-100, or run the 1/4, or top speed, or brake 60-0, or get so many g's on the skid pad, or attain so many mph in the slalom, or the way the seats feel, or the way the car looks, etc. Its combination of all of these that make a great car?
Your father has never even seen one, let alone driven one. So, whats your point?
with 3 mods, boost controller, exhaust, and intake the GTR will produce about 380hp, but its not really the total power we are looking at that makes the GTR one of the best cars in the world. Of course the are a lot of cars that can beat it in the 1/4, there are a lot of cars that can beat it a road race, but you would be hard pressed that could beat the GTR in every thing, but even if you could, that car is still no GTR
Old 07-16-2004, 09:15 AM
Deee's Avatar
Deee Deee is offline
Send a message via ICQ to Deee Send a message via MSN to Deee
Boost: max 2.2 Kg/cm2
Horse Power: 800 Wheel HP (920 BHP on Crank) @ 1.85 Kg/cm2 0-400m time: 10.95 SEC ( with stock gearbox)
Electronics: APEXi Power FC-PRO Drag ECU
Bottom end: HKS 87 mm forged pistons (x6)
HKS H-Beam connecting rods (x6)
JUN high capacity oil pump
Top end: JUN 272/272 lift 10.8 mm camshaft
Custom porting and polishing of cylinder head and runners with
extensive flow bench profiling
HKS exhaust manifold gaskets (x2)
HKS metal head gasket 1.2 mm
JUN cam pulley (x2)
Nissan Infinity 90mm throttle body assembly
Turbo system: T88H-34D GREDDY Turbine
HKS DRAG Intercooler
HKS Drag exhaust with Titanium Muffler
GREDDY Type c wastegate
Fuel system: NISMO 280 L/hr intank fuel pumps (x2)
SARD 1000c injectors (x6)
more details at www.speed-d.com
Old 12-16-2004, 01:07 AM
SkylineUSA's Avatar
Originally Posted by rev210
Car: 1991 R32 GTR
Kms: 236,000km
Mods: 3 inch exhaust front pipes back (cast factory dumps), Power FC , Tomei 260deg 9.15mm lift cams , M's air filters.
Boost: 10/11psi on factory turbos
a nice conservative tune this one considerate of the age of the engine. The timing and fuel maps are nice and safe. Note this is on a dyno dynamics dyno in shootout mode, there dynos read alot lower than the dynojet or hub style dynos.
dyno found here;
http://www.skylinesaustralia.com/for...chmentid=26559
Very nice.
How does the car idle compared to the stock cams?
Old 12-16-2004, 01:19 AM
rev210 rev210 is offline
Nice lumpy idle. Mine is lumpier due to the cam timing. I have gone for more power in the mid range by having 2degrees retard on the intake and 8 degrees on the exhaust. There is about 15-20hp to be gained by advancing both cams at the same boost but, it moves the power up the rev range. I wanted to keep the revs around 6500rpm for peak power. The turbo's make fullboost by 2800rpm. If I fit aftermarket split dump pipes and muck around with the timing map I can probably drop that another 300-500 rpm.
I also have lightweight pulleys fitted and have removed the factory belt driven fan in favour of an electric 16inch thermo fan and I also have a lightweight flywheel. This all adds to the response of the engine and gets you great exit speed out of corners.
milage how much do you have on you 3 DarkHadou SP23 3 9 08-16-2007 04:14 PM
How much power will a b18c1 have with an non-vtec block??? integra818 Engineering/ Technical 3 02-03-2003 01:28 AM
