View Poll Results: how much have you spent
50 to 100 5 8.20%
100 to 200 1 1.64%
200 to 400 9 14.75%
400 to 800 15 24.59%
800 to 1000 5 8.20%
1000 to 2000 14 22.95%
2000 to 4000 6 9.84%
4000 to 8000 1 1.64%
8000 to 10000 1 1.64%
10000 + 4 6.56%
Voters: 61. You may not vote on this poll
Old 08-10-2003, 12:13 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
2 amps, 800x1 for the sub and 85x4 for the speakers
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 08-10-2003, 12:17 AM
ssjwizard ssjwizard is offline
Send a message via AIM to ssjwizard Send a message via Yahoo to ssjwizard
nice im looking at going with an amp that will put out 130x4 for my speekers and 500x2 for my subs all are the RMS and at 4Ohms while this equipment is still a bit away thats for my final stereo upgrade when i finish the rest of the work on my car
Old 08-11-2003, 04:20 PM
Chairchild Chairchild is offline
Not only has he got a decent stereo, he's even managed to squeeze a coffee table and sofa into it!!
Never chase a lie. Let it alone, and it will run itself to death.
Old 08-19-2003, 12:14 AM
carkid22's Avatar
carkid22 carkid22 is offline
no car yet, but when i do get one almost all my money's going into my system. i'd love a super fast car but not until i'm older than 21.
Insurance rates make me angry
The only two tools you will ever need are WD-40 and duct tape. If it moves and it shouldn't use duct tape. If it doesn't move and it should use WD-40.
Old 08-26-2003, 12:08 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
900 give or take.
clarion dxz935, six kappa speakers, kenwood 350 and 600 amps, basslink.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 09-25-2003, 09:35 PM
IIwhitexb0iII's Avatar
IIwhitexb0iII IIwhitexb0iII is offline
Send a message via AIM to IIwhitexb0iII
Re: how much have you spent
Originally Posted by BigDanTheMan
900 give or take.
how is the basslink, i was looking at that... thanks in advance
Old 10-14-2003, 03:07 AM
No-Townhustla No-Townhustla is offline
$250 jvc kdlh 1000
autotek stealth series 1500.1 amp $700
2 autotek mx1222 12" $300
1 farad capacitor $99
custom box $100
installation running 2 gauge wire $100
kicker equalizer free
pioneer 6x9s 300 wtts $12 i got at auto junk yard i worked at
about 1500,
Old 10-14-2003, 11:08 AM
sr20de4evr's Avatar
just spent another $600 on my setup
I replaced the US Acoustics 4085 with an Avionixx 400.2, took out the rear kappas, and replaced the kappa components up front with focal polyglass components.
The focals get louder than all 4 kappas did, they're clearer, and have much more midbass. And I don't have any static anymore! damn us acoustics....
'01 Black Sentra SE
'05 Silver WRX STi
Old 10-15-2003, 02:39 PM
ChronicBrownie ChronicBrownie is offline
only 550 but thats cause i just done spending 8000 on the lift kit and modifications to it respectively.
Old 11-03-2003, 12:56 PM
03Tibby 03Tibby is offline
Send a message via AIM to 03Tibby
jl 13w7 1000
audiobahn A1800 amp... 400
pioneer head unit.. 479
subzone sealed box.. 150
Wires.. 130
Installs.. about 200
so around $2400
Old 11-03-2003, 01:07 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
relatively cheap system i have
sony xplode head unit - $80
sony xplode door speaker - $20 from a friend
kenwood 10" woofer in a bass tube - $30
sony xplode 10" woofer to replace the keenwood - $30
120w amp (all i could afford) - $20
wiring - $20
all together....$200....sounds good in my lil hatch....trying to keep it all xplode....i could use a better amp though
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 11-03-2003, 01:45 PM
kdizzle50 kdizzle50 is offline
Lightbulb
i have a 84 5.0 lx convt.. little trunk room so custom built box for two 12s which are here
<b> 12" Volfenhag Red Aluminum Cone Bumped & Vented Subwoofers $104</b>2 12" 1000 Watt Subs (2000 Total Power)<br>
Magnet: 160 oz. Double stacked Ferrite <br>
Frame: 5 spoke Die-cast aluminum basket<br>
Cone: Reinforced aluminum curvilinear<br>
Surround: Oversized buytl rubber<br>
Spider: 2 Flat ultra excursion<br>
Power handling: 500 watts RMS, 1,000 Watts max<br>
T Yoke: Industrial Chromed Hex bolt retained, Bumped and Vented<br>
Double damper magnetic motor assembly<br>
Cooling: Double Vented (T Yoke and Motor Side vents)<br>
Voice Coils: 4 Layer Dual 4 Ohm High Temperature black Aluminum<br>
Voice Coil Diameter: 2.2"<br>
Nominal impedance: 4 ohms / per coil<br>
DC resistance (Re): 3.2 ohms ea. coil<br>
Frequency range: 20 Hz-1.1 kHz<br>
Fs:30 Hz<br>
QTS:.526<br>
QES:.614<br>
QMS:7.698<br>
VAS:56L (1.98 cu. ft.)<br>
SD:.0491M<br>
SPL:90 dB 1W/1m<br>
Xmax:16mm<br>
Mounting Depth: 165 MM<br>
Mounting Hole Dia.:296 MM<br>
Net weight: 22lbs<br>
<p>
<p>
<b>Weirer 1000 Watt 4/3/2 Channel V12 Amplifier $45</B>
Smooth European Design <br>
Built-In Cross Over for Front and Rear Speakers<br>
2 to 8 Ohms Capability<br>
Adjustable 50Hz to 250Hz<br>
Advanced Adjustable Super Bass<br>
Hi-Low Input/Output<br>
Auto On-Off<br>
Power On and Fuse LED Indicators<br>
Looks and Sounds Great<br>
<p>
then on my back seat i have two 6x9 carpeted boxes $20<p>
<p><b> Thunder Storm 1100 WATT 4-WAY 6x9 SPEAKER PAIR! </b> <br>$9</b>6"x9" 4-WAY MULTI-AXIAL SPEAKER SYSTEM <br>
4 OHMS IMPEDANCE <br>
SENSITIVITY" 92dB (1 WATT/1 METER) <br>
MOUNTING DEPTH 3" <br>
1100 WATTS POWER HANDLING FOR THE PAIR <br>
550 WATTS POWER HANDLING EACH <br>
80 Oz MAGNET STRUCTURE <br>
FREQUENCY RESPONSE: 50-20 khz <br>
POLY INJECTION RED CONE <br>
2-1/2" POLYMIDE MIDRANGE CONE <br>
1" NEODYMIUM DOME TWEETER AND 1/2" PIEZO TWEETER <br>
<p>
<p>
<b>6x9 neon light rings $12 beats to music</b><p>
Old 11-03-2003, 01:48 PM
Fs:30 Hz<br>
QTS:.526<br>
QES:.614<br>
QMS:7.698<br>
SD:.0491M<br>
SPL:90 dB 1W/1m<br>
Xmax:16mm<br>
<p>
<p>
Auto On-Off<br>
<p>
<p>
<p>
Old 11-05-2003, 09:24 PM
ToyTundra's Avatar
ToyTundra ToyTundra is offline
factrory head unit Free
600w sony amp 3 channel 200
sony 3 ways 100 (crap)
kenwwod midbass speakers 80 (Not hooked up replaced with sub)
10" infinity sub 80 (i like)
sub box 55
wires/ misc 120
total 635
wanted: Infinty kappa compnets, 800w sub amp
Old 11-05-2003, 09:30 PM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
600 on 2 decks, 250 on a sub/box and amp
300 for 2 pairs of 5x7 speakers and in a few days im spending 580 on 2 15's and an amp another 200 on a box and wiring
all installed myself
so about 1800 +-
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
