Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 07-21-2003, 02:45 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
I had 2 broken studs in addition to the cracked manifold.
Xterra4x4.com and the Xterra Offroad Webring
Old 07-21-2003, 08:39 PM
Toy Man Toy Man is offline
AF Premium User
I had several broken studs also. (and then Nissan sent the wrong studs.) Was in the shop three days getting it all sorted out.
Toy Man
Old 07-21-2003, 11:17 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Are you sure they were broken before they started trying to remove the manifold? I've heard of studs breaking when a wrench is put on them, but I don't know that they've broken from stress.
Brent
Old 07-21-2003, 11:49 PM
ChuckH's Avatar
ChuckH ChuckH is offline
Yes, some people have had broken studs. I think Andrea in PNWX had one or two broken studs too. I think what happens is the manifold not only cracks but also warps in some cases. The warping is what breaks the studs. I can't wait to see what mine look like when I finally get around to getting headers on.
ChuckH
Old 07-22-2003, 08:09 AM
Right, that was the original problem, warped manifolds pulling on the studs. Looks like they've come full circle.
Old 08-10-2003, 10:36 AM
boodie boodie is offline
Strangely enough, I had the warping problem on my '86 Toyota-based RV. The 1-ton truck had 100K on it, and the exhaust manifold (4-cyl) warped. It was obvious with a long straightedge.
I'm the 2nd owner, and after talking with an (unrelated) engineer, he speculated that after years of heat-cycles, the manifold changes crystalline structure, allowing warpage. He also said it should habe stabilized, and I should no longer have a problem with it warping.
...OK...Sounds good to me...
It only cost $35 to have the manifold surface-ground; I installed oversize studs at the same time...
No cracks...cross fingers...
Old 08-31-2003, 11:24 PM
X-Phile X-Phile is offline
See, I got a totally different story from the mechanic at the dealership that does my work. I was told that the reason the bolts break is that the exhaust does not have enough play to move with the engine. As far as the manifold itself, yeah he said they all have that flaw.
But whats right about the bolts?
Automatic Transmissions are for Old Women and Little Boys.
I do NOT baby my X damn it!! Now gimme that diaper so I can wipe off this dust.
Old 09-01-2003, 01:58 AM
O1SalsaX's Avatar
O1SalsaX O1SalsaX is offline
Send a message via AIM to O1SalsaX Send a message via Yahoo to O1SalsaX
When I had my manifold changed they said that it sheared two of the studs in the block. That must've really sucked. Having to drill it out and tap them. Well, I guess it was easier to do since they had the cylinder head off to change the head gasket at the same time.
'01 Salsa X XE
Bone Stock, No really.
Old 09-01-2003, 01:58 PM
XTerra Guy
Re: 2003 Exhaust manifold
Most everything I've heard goes along with your mechanic's description. We have people in our club who have broken the same manifold in a matter of months, so it has nothing to do with breakdown of the metal but rather stress on it from the exhaust leveraging the manifold.
And Brent, mine had at least two sheared off bolts as well . The shop manager said it was a bitch to get the thing repaired.
Old 10-05-2003, 03:50 PM
ChuckH -
What headers are you looking to put on???
Old 10-05-2003, 07:51 PM
XTerra Guy
Well I've got those nice big Calmini stickers and those are worth mucho power gains!
That must be why you have 3 on your truck. Tripple HP
BTW thanks for the free delivery.
2003 Grand Marquis LS Exhaust Manifold pcmos Grand Marquis 6 10-07-2010 08:09 PM
exhaust crossover or exhaust manifold? McLin Lumina 0 08-24-2008 02:11 PM
Need 2003+ Oem Exhaust Manifold! under8seconds Cavalier 1 06-17-2005 11:21 PM
Exhaust manifold drockg20 Engine 5 02-12-2005 07:23 AM
primera exhaust manifold barrlucas Engine 4 06-14-2001 11:12 AM
