Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 10-10-2023, 02:43 PM
Nehmo Nehmo is offline
Re: Bleeding Replacement Master Cylinder
I've successfully bled the brakes. I discovered 3 line leaks in the process and repaired them. The "pedal" is now firm when pressed a short distance.
The van uses the bubble flange at the tube fittings. I used a combination of double flange and bubble flange because I started by replacing part of a line with a double flange replacement tube. Everything under the van, including the brake lines, is rusted
I still need to fix the parking brake. I need to put an exhaust tube between the catalytic converter and the muffler. And I need to fix the turn signal switch in the steering column.
