Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 03-27-2020, 10:25 AM
merrillwebb merrillwebb is offline
Re: transmission removal
Oh yes also put my port a power between the frame and the hub support then used the puller then hit with the sledge. and won't budge
Old 03-27-2020, 10:47 AM
82Stang 82Stang is offline
I read others had the same issue. Needed to pull hub and axle and put in a press to get each outer side out of hubs. The part on inside of axles into trans, was stuck clips and needed a lot of persuasion. One was able to go through trans passenger side , like I said with a small flat screwdriver and beat from inside out. Another used a big screw driver/wedge in front of driver side axle and trans, then pounded upward and finally the c-clip clicked and the axle fell out. Have to do it straight out, not on an angle. A lot of effort, but it finally worked in the end.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
