Old 10-30-2019, 07:42 AM
John18d John18d is offline
Re: Top Studio RC213V exhaust pipe
Peter the paint work and decals are well done.
are you using Tamiya paints for the small parts like the engine or are you using "Mr. Color"
The engine looks great - did you use the Top Studio clutch ?
Very well done for someone that is a beginner
Cheers Peter
John
The Following 2 Users Say Thank You to John18d For This Useful Post:
peterngtr (10-30-2019)
  #17
Old 10-30-2019, 07:48 AM
Peter if you choose to clearcoat the body work and you use 2K clear then airbrush very thin "tack" coats first 2 or 3 coats before you try to apply a thicker "flow" coat that looks really glossy.
2K clear is very chemically reactive and gets hot when it cures - This can cause the decals to melt okay - so for the first 2 or 3 coats of 2K clear just "mist" it on with an airbrush so that the decals get sealed under the misted clear and give it a day to cure before you apply the flow or wet coat of 2K clear.
You have done an excellent job so far I would hate to see the decals damaged by a heavy coat of 2K clear.
Cheers Peter
John
Old 10-30-2019, 07:52 AM
peterngtr peterngtr is offline
John, I use the mr color for everything of my build, to be host, that mr colors are great. And only the accent wash is from tamiya
Yeah the clutch is from the Top Studio Super detail up set. Can't image that brings such a super detail level like that.
Old 10-30-2019, 07:53 AM
Peter which paints are you using?
for the bodywork and also the small parts?
Which brand and which colors?
Did you use the Tamiya maskings for the body work?
Very impressive for beginner - this can be a difficult kit with the Repsol livery
Well done so far
Cheers
John
Old 10-30-2019, 08:04 AM
John, yes, I used all the paints from mr hobby from base coat: mr surfacer 1000 to the main coats along with the mr level thinner. I'm thinking of using this to apply the clear coat, after that will be the polishing.
I used the masking tapes from tamiya and revell.
Old 10-30-2019, 08:13 AM
Peter which Mr. Color did you use for the Fluorescent orange and red?
Can you post a picture of them or can you post the "number" on the bottle.
Thank you
John
Old 10-30-2019, 08:15 AM
Also Peter that is a "flat" or "matt" clear - you would want to use a "gloss" clear coat for the bodywork
You cannot polish a "flat" clear into a glossy finish - you must use a "gloss" clearcoat
Cheers
John
Old 10-30-2019, 12:29 PM
Hi John,
Thanks for the tip. I would think we can polish it regardless the matt or gloss.
Here are the numbers:
Mr color 173 fluorescent orange
Mr color 171 fluorescent red
Old 10-30-2019, 01:14 PM
Thank you for the paint code numbers Peter.
You cannot polish a "matt" or "flat" clear - it will not shine like the gloss coat will - the real bike is "glossy"
I would hate to see you have to refinish the paint and decal work because you made a mistake by using a "flat" or "matt" clear.
Mr Hobby has several clearcoats in "matt" - "semi-gloss" and "gloss" - for a shined surface you need a "gloss" Peter
Ask the people of the forum -
Cheers
John
Old 10-30-2019, 03:26 PM
Thanks John for the comment. I would definitely use the glossy clear paint. I learned a lot from you.
Old 11-01-2019, 08:10 AM
Raikkobin Raikkobin is offline
Hi, fantastic work for a new builder! Clean and you are already using very advanced techniques. Keep it up!
A tip for forming photoetched pieces that require bending and keeping a shape. Try heating the pe part over a flame from a candle for 10 seconds or so. It will soften the material and make it less springlike and easier to form.
Old 11-01-2019, 08:50 AM
Thanks Raikkobin. I would try your tip when working with PE parts.
Can’t imagine how hard it is to deal with little tiny things. Just a bit impatience could ruin your efforts. Not a bit update thou, just wanna show this.
Old 11-01-2019, 08:52 AM
Cheers
John
Hi John, so I just order the gloss super clear as your advice. Thanks for your reply.
Old 03-27-2024, 10:53 AM
Hello Thanh - This is John from Arizona USA - We used to chat by email thru Scaleworks365 model website That was closed down a few years ago. Do you still live in Germany? Are you still building racing motorcycle models? How can I re-connect with you on the internet?
Thanks
John
Old 03-27-2024, 12:38 PM
Hi John, it’s been a while. I‘m glad to hear back from you. So yeah, I’m still in Germany. I haven’t built any more since. My latest project was Honda RC211V 06.
How’s it going? Are your still building something?
