Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 05-27-2018, 08:40 PM
Stedia10 Stedia10 is offline
Question Re: Electrical confusion
How do I find this fuse link? All my wires are wrapped and I don't know where its located? I've looked on YouTube but all I get is "There Are Fuselinks everywhere"!?
Old 06-01-2018, 09:33 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
A fusible link on a GM car will likely have a plastic 'cylinder' on it, where it joins the rest of the electrical system. It will be one of the smaller wires, and it will have a different, sort of rubbery insulation on it. If the fusible link blows, chances are this rubber will be bubbly due to excessive heat. Visual inspection is not good enough; you must check continuity. You can do this with your meter set to Ohm scale (the lowest setting) or Diode Check. If you touch one probe to one end of the link and the other probe to the other, you should get 0 ohms, a light or a beep. If you get infinite ohms or some other value, then you can suspect the fusible link.
File Type: jpg starter_a88b0ac2aefa0707edc4a188172be6bd72a81ce3.jpg (299.1 KB, 4 views)
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-02-2018, 10:32 PM
Thumbs up Re: Electrical confusion
Thanks to everyone who helped me get my truck back on the road!!! It WAS the fuse link! Next time I mess with the radio, I'll unhook my battery!!!! Lol! You guys are AWESOME!!!!
Old 06-04-2018, 01:17 AM
silicon212's Avatar
Confoundingly Lucid
Great to hear.
