| WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
#16
i think that you should maybe flare the arches a little to give it a wider stance seeing as you have lowered the front and made it so aggressive.
in doing this you could even up the front wheel arch where the new front sits. all in all top man for starting an ambitious project, and i know you can pull this one off, your work i have seen is great, so keep sanding and adding bits till you are happy. people always try and put you down when u do better than them, i am backing ya all they way dude. good luck and keep building |
#17
Looks alot better when you sanded it... A wide body would set that mug off real well... Good luck and keep the updates coming!!!
#18
Hmm... OK, maybe it does look better than I thought it would
![]() Keep up with the progress pics!
Chris
#19
Looks sweet
I cant put a poll in anymore so here it is...Vote please
1. Widebody 2. Fender Flares First 5 or sumtin votes will be counted cuz i dont want to wait that long
-Andrew-
#21
1. Widebody
2. Widebody 3. Widebody 4. Widebody 5. Widebody There, you got your 5 votes What putty are you using by the way? Can you possibly take a picture of it?
Its bondo glaze coat (same as bondo just smoother texture)
-Andrew-
#23
Also, I need some ideas for the back of the mini
it cant look too plain and i decided the mr-2 lites would look crappy so, ideas please
-Andrew-
#24
I have an ideal:
An open top, two seater with, big GT wing, split exhaust!? |
#25
r u gonna make sideskirts?
i think u should put a sunroof, dual oval exhausts, a frenched license plate(i think thats what its called), wide body, and supra tail lights
Took the words out of my mouth. Supra tail lights on a widebody rear would make it look sweet. Bigg "E"
"Follow the white rabbit."
#27
Does anyone have a pair of supra taillights (and housings for them from the model if possible) that I can have off a spare model? Cuz that sounds like an awesome idea especially with that real wide back
-Andrew-
#28
Blown... is the bondo you are using easy to use, in terms of applying to the car and then sanding into shape? ANd have you used any other putty before? If so, how does this compare?
#29
No, this is the only putty i have used...I put this stuff on with my finger and it sorta flattens itself down pretty good
it is a 2-part kinda thing, you put the main part then there is a little tube of hardener that gets mixed into it also, should i do a cover over the back with the little lumps behind the seats like that orange WRX that vric's dad (i think) did?
-Andrew-
#30
where can i get this putty?
how much is it? did u make the widebody kit with just a pile of putty or a little bit of plastic underneath the putty?
