Old 01-18-2021, 08:13 AM
michel1973's Avatar
michel1973 michel1973 is offline
Re: 1/12 1965 Ferrari 275 P2 Targa Florio Matildemodel
Can't wait to see the result
my English is not perfect but hopefully be readable
Old 01-18-2021, 10:21 AM
stefanone stefanone is offline
Do not worry Michel , also my english is not so perfect .
In my latest post you can find the picture of the model assembly template. Could be useful to set the model , all the measurement of the parts to make it you will find in the instruction . To made it you need a lot of plastic 2mm thickness and one base 40 x 24 cm . Whith this tool you will can determine what the correct height from the ground . All the best .
Old 01-19-2021, 12:45 PM
Hello everybody , I keep showing you the parts that make up the model , now the Weber carburetor . 6 are needed . Enjoy
Old 01-21-2021, 03:59 AM
Good morning all , I want to showw you all the p/e and white metal parts of the 1/12 Ferrari P2 ; are they few ? are the necessary ones .
Old 01-21-2021, 09:12 AM
Hello , compared with post #7 , you can see the necessary modifications to the engine frame , this because the first version of the exhaust pipes were too thin , 2.5 mm of diameter . With the correct diameter of the pipes they touched at various points so I prefere to change the design of the frame . Now the exhaust pipes run free to the back of the model
Old 02-06-2021, 04:09 AM
Hello All, in the body the rivets are highlighted but not all are perfect so if desired you can drilled 0.7mm and use MFH rivets or various soldering balls . Find everything on the aftermarked.
Old 05-24-2021, 04:42 AM
Hello everybody, the Job to update the body is ended and you can see the result , all the rear parts are now made with the help of rapid prototyping. For any solution I have a reason, for the rear hood this was made to get a perfect loopholes, impossible to have so clean in any other method. The lower rear parts is too thin to get it with resin.
PS The rollbar is not fixed in the pictures because ie well to spray white and red separated.
Enjoy.
Old 09-02-2021, 09:20 PM
360spider's Avatar
The body looks great!
ItalianHorses.net
Old 09-15-2021, 10:30 AM
Hello evrybody, my work proceeds very slowly, but proceeds. I decide to put rivets only in the visible parts , despite this they are still 400. I chose the brass nails ones from the Amati Company , Torino, Italy.
The Following User Says Thank You to stefanone For This Useful Post:
360spider (09-15-2021)
  #25
Old 11-17-2021, 11:23 AM
The dashboard is on fire . I prefer to scratchbuilt all the buttons. They are made with some little white metal clippings, present in every good model spare parts warehouse
Old 01-20-2022, 05:22 AM
Another little step forward. On the front chassis you have the supports for the suspension arms . I used the p/e parts , so i cut the white metal , so the group will be more strong
Old 02-02-2022, 12:49 PM
Good evening everybody , a Ferrari V12 need a lot of parts put up , here you can see the main in a row. From the naked engine to complete before being fixed inside the chassis .
Old 02-04-2022, 12:34 AM
360spider's Avatar
Wow, engine looks great!
ItalianHorses.net
Old 02-04-2022, 05:38 AM
I'm glad you like it
Old 02-13-2022, 04:23 AM
Hello everybody , before starting to assembly overall model , there are some parts , some accessories to prepare .....
