Go Back   Automotive Forums .com Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 02-16-2017, 07:41 PM   #16
Crvett69
Crvett69's Avatar
Re: 1997 sentra no start spark plug tubes full of oil
not something simple like out of gas is it?
Crvett69 is offline   Reply With Quote
Old 02-16-2017, 07:43 PM   #17
krackerjack9
no its full of fuel,
krackerjack9 is offline   Reply With Quote
Old 02-23-2017, 05:43 PM   #18
krackerjack9
ok going to give it a go again, brand new spark plugs and wires, but got 3 different answers on firing order, I'm going to try the one on the dist cap first then try the others, I due have spark and fuel,, only got about 2hrs before it gets dark
Old 02-23-2017, 05:52 PM   #19
Crvett69
Crvett69's Avatar
you can spin the engine to tdc by the mark on the engine damper and see where distributor rotor is pointing. that will either be #1 or 180 degrees out, can use that as #1 and crank engine to see what direction rotor turns then set the wires up 1-3-4-2 in direction rotor turns. if that fixes it great, if it backfires or wont start can start #1 directly opposite one you used before and change other wires accordingly
Old 02-23-2017, 06:08 PM   #20
krackerjack9
still nothing, I know I have spark, so where due you check for fuel pressure??
Old 02-23-2017, 06:18 PM   #21
krackerjack9
Unhappy Re: 1997 sentra no start spark plug tubes full of oil
thought there be a tap but looks like I got to splice a hose...
Old 02-23-2017, 06:41 PM   #22
Crvett69
Crvett69's Avatar
you can also take the fuel line off the throttle body or injectors and stick it in a gas safe container and make sure it has a good flow when you turn key on. it will only pump for about 2 seconds so might need a helper
Old 02-23-2017, 07:29 PM   #23
krackerjack9
so far nothing, cant get my fuel pressure guage on fuel filter I got hose to small or hose to big,, I am about 90% sure I got the spark plug wires in the correct positions, found a photo on Nissan forums and its the 3 rd different one I have seen, the spark plug wires are different postions than what the distributor says, so I guess I'm going to roll the dice and get a fuel pump and see if that's it, its 48 miles one way to a store so might as well buy one
Old 02-23-2017, 07:31 PM   #24
krackerjack9
yeah fuel came out when I turned the key on for about 2 or 3 seconds then it shut off.
Old 02-23-2017, 07:59 PM   #25
krackerjack9
Talking Re: 1997 sentra no start spark plug tubes full of oil
http://i30.tinypic.com/29db5gh.jpg
this is the one the did the trick,, hope that comes out. But the real thing that did the trick is I pulled the fuse to the fuel pump cranked it for a bit and then put it back in as soon as I turned the key it fired right up.. now to read up on sealing up those spark plug tubes so oil one get in there
Thanks
Old 02-23-2017, 08:00 PM   #26
krackerjack9
heres the other one
http://i25.tinypic.com/mc9qaa.jpg
Old 02-23-2017, 08:16 PM   #27
Crvett69
Crvett69's Avatar
glad you got it going
Old 02-23-2017, 09:12 PM   #28
krackerjack9
Wink Re: 1997 sentra no start spark plug tubes full of oil
Crvett69 Thanks for taking the time to respond so some of my request. I still cant believe by just pulling the fuel pump fuse did the trick. Now the seal on spark plug tubes and crank seal and I'm good for another 100k
