Old 03-11-2016, 11:17 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 1995 3000gt overheating need help
The people bypassing it have probably deleted their AC.
Old 03-13-2016, 02:59 PM
hollydolly hollydolly is offline
can I go without replacing the alt/ac tensioner pulley? my voltage is normal when I get in it in the morning. when I stop like a stop light is only time voltage goes down. what damage will happen if I just leave it seized up? can I run my a/c without a new one?if it wont mess anything up ill just leave it for now.
Old 03-13-2016, 03:29 PM
Stealthee's Avatar
Voltage drop at a stop light is normal. If your idle is low from a bad IAC that will make the voltage drop more prevalent.
If the pulley truly is seized though I would get it replaced. It could burn the belt up which in turn could cause it to shred, which could wrap around the crank pulley and make the car jump time. I have seen it happen more than once.
Old 03-13-2016, 04:59 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
yes, if pulley is seized the belt would have gone up in smoke in a couple minutes or running
Old 03-14-2016, 01:51 AM
MikeCStig MikeCStig is offline
Generally speaking, running without an idler pulley is a bad idea. The idler pulley maintains tension on the belt to keep it from slipping on the other pulleys. When belts are too loose they wear out faster, the idler pulley is usually adjustable so the belt can be kept tight through normal wear and tear.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
Old 03-15-2016, 07:54 AM
the belt has come apart.I need to have it taken off until I can afford a tensioner don't i.I have to run without replacing it for a couple weeks until I can afford it.
Old 03-15-2016, 07:13 PM
Stealthee's Avatar
Considering you need the alternator to drive the car, and you need the tensioner to tighten the belt, there is no way you can run the car unless you replace the tensioner and belt.
Old 03-17-2016, 04:47 PM
can u send me a link to this part for 101.00 .Ive looked and looked for it on 3swarehouse and cand find it.
Old 03-17-2016, 04:50 PM
Originally Posted by Stealthee View Post
That's not the right one. The listing is in error. That pulley is an idler. The pulley she needs is the one that says Ref 55-430.
Please send me a link to this part.I cant find it on 3s warehouse site.
Old 03-17-2016, 08:16 PM
Stealthee's Avatar
https://3swarehouse.com/product/accessory-belt-pulleys/
In the drop down select DOHC Alternator/AC Compressor Tensioner Pulley
