| Latest | 0 Rplys |
| WIP - Muscle Car / Hot Rod Post topics for any "Works In Progress" Muscle Car-Hot Rod vehicles projects in this sub-forum. |
Show Printable Version | Email this Page |
#16 | |
Re: Revell 68 Hemi Dart with MCG Photo Etch Set
finally some more work done on this one.
I got a little further with the rear end and did some work on the interior. I just need to do the console and steering wheel/column I used .8mm brass nuts from Scale Hardware and threaded them onto some Detail Master aluminum rod. ![]() ![]() ![]() ![]() Made the keys ![]() polished the interior parts ![]() Got ahead of myself ![]() I applied the foil before painting, then removed the paint with a firm conical swab ![]() ![]() Painted, then weathered the panels, then applied the PE pieces ![]() I don't have much experience with foil and I am still not great at it, but the point of this build is to better my skills and test a few things. I have no emotional attachment to it, so it doesn't need to be perfect. I tried to do the dash, but I think it would have been better to use the same method as the door panels. Some of the foil got messed up. rather than messing with it and likely making it worse, i decided to leave it. It's not horrible ![]() ![]() ![]() ![]() ![]() I used PE washers for the knob faces and the glovebox lock cylinder ![]() It doesn't look this worn in real life, the pictures make it look way more weathered ![]() ![]() The gauges are acetate from the Model Car Garage detail set. |
#17 | |
I took the seats out and added flocking. I have never done flocking before, but Alex's tutorial made it easy.
![]() ![]() ![]() ![]() before weathering. Looks too new and clean ![]() ![]() After weathering ![]() |
#18 | |
Great work!!!This is one of the MOST interesting work I've seen in a long time. I am delighted With the work you're doing. You're very careful about details and how you work some pieces made from scratch. It's fabulous! I follow your progress with great interest. By the way, what happened with your old job 1/12 '57 Bel Air ??? You published some pictures of the engine detail, but nothing more. By the way, great job. Have you abandoned that project? Kind regards, Ed
"The madness deserted of the reason creates monsters, but together they create the mother of the arts." Goya "La locura abandonada de la razón crea monstruos, pero unida a ella es la madre de las artes." Goya |
#19 | ||
I pretty much finished the battery tonight. I added the anti-corrosion donuts. Just painted some PE washers. Shaved off the molded in posts and drilled a hole, made the new posts from aluminum rod. PE cable ends from the Model Car Garage set I think I will still add PE battery mounts with wire rod. It looks incomplete with the top silver bar and nothing on the sides. ![]() ![]() ![]() ![]() |
#20 | |
So a little update. Painted with Scale Finishes Harley Davidson Sinister Blue metallic. Paint went on fine. The lacquer clear I use went on fine for the couple of test spoons, but when I sprayed the body, it was heavily textured and cobwebs everywhere. I let it dry in between coats and buffed off the cobwebs, then laid down a nice wet coat, hoping it would settle out. It didn't. I am still learning a lot about painting, so I didn't know any better. I bought a new can of the same stuff and it's a night and day difference. I also should have though about thinning it.
Anyway, I sanded and polished the hood and scoop and you can see how nicely those turned out. I still have to sand the body, and I will re-spray a couple of coats of clear on that before polishing. Here is the body, you can see what I ended up with ![]() ![]() ![]() Here is what I got out of it with MicroMesh and Tamiya compounds ![]() ![]() ![]() |
| The Following User Says Thank You to Hemi Killer For This Useful Post: |
Lee Yoder (12-06-2015)
#21 | |
Very nice work so far! Great detail. I too am returning to the hobby and learn so much from this forum and youtube. Definitely subscribed!
Later, Lee |
#22 | |
looks great so far
CLIFF
| The Following User Says Thank You to rambenna For This Useful Post: |
zed red (04-12-2016)
#23 | |
This is a fun great work in progress to follow. Look forward to your updates, keep up the good work.
#24 | |
nice work congratulations, enjoyed the engine details
#25 | |
I swear i can hear that engine roaring!!
great work... btw is there a reason you keep the instructions of the tamiya F360 pinned to your wall? |
